[ View Full Version Of This Page ]
1980, 305
All Forums » 2nd Generation » 1980, 305
AFO
5/24/2005 9:53:46 PM
hey, new to camaros and ive got a big problem my gasloline leaks into the oil i have changed the fule pump and it still seems to leak in there. when ever the car gets started up the fule will go up a lil bit more than the last time. anyone no what is wrong here?
Sidewayz6.0
6/3/2005 5:52:30 PM
I guess I'm not following here. If the gas is leaking into the oil...Which I'm not positive how thats possible, but why would the fuel be going up? If it's leaking out?
azsoprano2
6/6/2005 5:31:04 PM
Unless the new fuel pump is defective, the only other way is if is leaking from the carb into the intake and so on.
Check your fueil pump again...
nj02z28ls1
8/11/2005 9:42:47 PM
that might be coolant from a bad head gasket, all my years with cars i never heard about gas in the oil, but you never know.....good luck
aaronsirocz
8/12/2005 4:03:04 PM
yes, definately check out the head gaskets, that would cause that prob.
Related Threads
Return to the Camaro Forums home page - Archive Home
