Where can I get Wiring Specs (97 RS)...
Old Nov 20, 2009 | 11:18 AM
libertyforall1776's Avatar
Do you want any of the diagrams below?
Engine Electrical
RH View Engine Wiring Harness L36
Transmission Engine Wiring Harness LT1
Front View Engine Wiring Harness L36
RH View Engine Wiring Harness LT1
LH View Engine Wiring Harness L36
LH View Engine Wiring Harness LT1
Transmission Engine Wiring Harness L36
Old Nov 20, 2009 | 11:46 AM
Toneman07's Avatar
he needs engine electrical
Old Nov 20, 2009 | 12:30 PM
interest007's Avatar
ok. Maybe what I'll do is bring it to a stereo installation shop and get them to look inside my wiring.... Unless someone knows a better place to go. My mechanic said that wasn't really their area, when I asked them. (I unhooked the deck btw, not just the face, but I was considering that, too. Only, I can't understand why it makes the car not turn over for an indefinite amount of time?.... What's going on inside it? I was even considering that the fuel-air might be off, and eventually it was clearing out... like somehow it wasn't getting enough air. Or computer?...
What exactly is engine electrical?
Old Nov 20, 2009 | 01:15 PM
  #14
Lightbulb
Here's Figure 2- Ignition Control, Knock Sensors (attached)
Any others you think would help?
Engine Controls Schematics
Figure 1: Grounds, Serial Data, DLC
Figure 2: Ignition Control, Knock Sensors
Figure 3: Fuel Injectors
Figure 4: Fuel Pump Control
Figure 5: A/C Refrigerant Pressure, TP, MAP, ECT, IAT Sensors
Figure 6: MAF Sensor, EVAP System, EGR Valve
Figure 7: HO2S Sensors
Figure 8: Cruise Control, VSS
Figure 9: Gen Control, IAC, Check Gauges Lamp
Figure 10: 2nd Gear Start, Clutch Anticipated Switch
Figure 11: Brake Switch, TCC Solenoid
Figure 12: Trans Range
Figure 13: A/C HVAC Control
Figure 14: Cooling Fans
Old Nov 20, 2009 | 01:57 PM
  #15
Toneman07's Avatar
well try a crankshaft position sensor might help start up but doesnt account for car randomly shutting off
  #16
Toneman07's Avatar
Can we see figure 1 please ground wires etc... this would probably be where his problem is
Old Nov 20, 2009 | 02:12 PM
  #17
Attached.
Old Nov 23, 2009 | 04:25 PM
  #18
But the drain might, you think? Is that what was happening to your friend's Mazda? If so I'll go with that. I also have an opinion from a guy it might be the problem is ignition related items are heating up and shorting out. Then when those items cool down the car starts.
Old Nov 23, 2009 | 05:04 PM
  #19
Do you have a check engine light? If so, what are the codes?
iCrossbone
Apr 7, 2011 07:12 PM
Lopez_SS
Feb 10, 2008 10:08 PM
SYDEWAYZSS
Nov 8, 2007 10:58 PM
350rs
Nov 6, 2007 05:17 PM
Toronto_Ben
Sep 22, 2006 07:48 PM
