Sofie's interior project
So I started working on her custom interior today. I spent 7 hours working on it after working 4am-9am already this morning. I only did her rear (I know, it's gonna look odd until I finish it). Here's a few pics (they don't do a justice, much better looking in person).
The lighting isn't the greatest, so it doesn't look that nice. But you get the idea. I have more pics in my album https://camaroforums.com/forum/members/darlingreject-19581-albums-miss-sofie-578/
Not trying to tell ya what to do, but putting a cover like that over your amp is'nt a good idea. Unless you have cooling fans built into that cover somewhere your amp is gonna run at a way higher temp. than it should. Be carefull once you let the smoke out of it you can't put it back
Cool deal! Just wanted to make sure you took ventilation in to consideration. I had a friend once that thought it would be a good idea to mount a memphis 100a high current amp ($500) under the seat of a third gen. Bet you can guess how that worked out. But I do like the progress so far lookin good
Thanks for the concern. It was a big one when trying to figure out where to install it and how to try to hide it (I'm very paranoid on top of everything). So there's a decent amount of clearance on top, and then the short sides of course. It's less visible now with everything turning black, so the window tinting will probably do the trick. I check it often though just in case.
No, I'm still stuck on what to do. I thought my mom could make them, but her sewing machine sucks and can't do any kind of thick fabric. So I don't have a clue yet. That's the last issue to tackle with the interior.
Well I think your doin' a fine job on it, I had a set up similar in a 4th gen, When you get that all taken care of and nothing to do, gimmie a shout, I will drop mine off to you and you can work on mine...lol
