Heads and cam
Old Nov 12, 2009 | 08:07 AM
nazariol's Avatar
Default Heads and cam
Hi guys!
I Am getting a heads and cam kit for my 99 ls1!
i was wondering which heads which cam and should i get rockers and lfters and how much would it cost to install?
Old Nov 12, 2009 | 08:17 AM
maudyZ28's Avatar
what are your plans for the car, im in the process for getting these part but have een doing research for 5 months so far.
Do you run and auto or a manual, do you drag race, what are your supporting mods, and what 1/4 mile time or car WBHP do you aim for??
Im reply to rockers, yes if you have over 0.550" lift get some rollers. stocker will be ok but wll wear out aftermarket bronze valve guide do to their motion on over the top of the valve. I have been advised that stock lifter are ok on normal milage engine that has been well maintained, 80K or less. But if you have the heads off and you have the cash get some new replacement lifters, you dont need race ones for street applications
Old Nov 12, 2009 | 12:00 PM
check this place out and give lloyd a call.
http://www.elliottsportworks.com/ls1.html
Old Nov 12, 2009 | 08:53 PM
cbr600rx7's Avatar
What other mods are you running. Intake, headers, etc? A4 or M6 car?
Old Nov 13, 2009 | 02:56 AM
KPI's Avatar
KPI
It's hard to go wrong with AFR or TFS heads.
If you don't have one already, LS6 intake should be on your list.
Old Nov 15, 2009 | 08:47 AM
nazariol's Avatar
Thanks guys!
Current mods are ls6 intake paceseter longtubes to custom exhaust, cromo lifters, z06 clutch m6 full suspension
Old Nov 15, 2009 | 12:32 PM
maudyZ28's Avatar
ported ls6 heads, sound good . where do you want you power band, its different trying to set up a cam for an auto vs a manual.
the guys at TSP are good to talk to and do reasonable packages, depends on your budget.
ls6 proted heads, dual value springs and a 228R will put down over 400rwhp, bigger duration pushes power and torque up and you lose a bit down low
Old Nov 15, 2009 | 07:46 PM
cbr600rx7's Avatar
A milder cam would be the way to go stall below the 23X range on duration on both sides and keep it around a 112-113 LSA. That should still give you some good low end and still open her up on top. AFR is probaly the way to go if you dont mind forking out the cash.
Old Nov 18, 2009 | 08:23 AM
reaperchild's Avatar
I understand you can go for big cams on manual tranny but for auto its a bit differnt !!
Old Nov 18, 2009 | 12:32 PM
evilkal's Avatar
It's only different for an auto if you don't have a high stall torque converter. Even then you can go big on a cam for an LS1.
