Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Push Rod Checking
  Printable Version
Camaro Forums >> Brand Review >> Engine & Internal >> Push Rod Checking Page: [1]
Login
Message << Older Topic   Newer Topic >>
Push Rod Checking - 8/9/2007 8:45:27 AM
z28pete
Status: online
z28pete's photo gallery
Pushrods, from Comp Cams
The pushrod is the weakest part of the valve train, and in high RPM applications, the stock pushrods can bend under the high load.  When doing a cam swap or installing high ratio rocker arms, be sure to check your stock pushrods to make sure they are straight.  Simply roll them on a flat surface, and if they don't roll well, they are bent and need to be replaced.  The stock pushrods are strong, but higher output engines should upgrade to a one piece chromemoly setup.
A major problem in high RPM engines is incorrect valve train geometry.  Make sure that you have the correct length pushrods installed.  The easiest way to check is to take a magic marker and color the tip of one intake and one exhaust valve.  Then, install your pushrods and crank the engine over a few times.  Now uninstall the rocker arms and look at the tip of the valves that you colored.  The marker will be worn away where the rocker arm was in contact with the valve.  This line left should be in the center of the valve.  If it is towards the exhaust side of the head, you need shorter pushrods, if it is towards the intake side of the head you need longer pushrods.
_____________________________
Pete
Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Brand Review >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5449
spectergt2603735
madmikez283657
95slvrz282767
74454bb2688
cplthomas2439
bluovlh8er2400
blade2299
02stangt2192
ninetysixyen2071
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
K&N Engineering, Inc.
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
