GM Tech Info, cams, springs, etc.
Login | |
GM Tech Info, cams, springs, etc. - 11/16/2007 3:58:15 PM
z28pete
General Motors Engine Technical Specs & Information cam specs, spring info, and more... GENERAL MOTORS TECHNICAL INFORMATION PAGE ONE Small Block and Big Block Chevrolet engines have become legendary since they were introduced over 50 years ago. The people at COMP Cams®, along with a lot of top engine builders, have spent many years improving these and other Chevrolet powerplants. We know the basics, and the basics are important. We have also learned a few tricks along the way. If you’re rebuilding an engine, it will be worth your while beforehand to either read our books or watch our videos on the subject. If you need more help or have any questions, call our CAM HELP® line at 1-800-999-0853. Engine Types V6 90º -uses “18”, “09” and “56” Prefixes The 4.3L V6 90º engines produced since 1985 are equipped with two types of camshafts and three types of cam drive systems. Early 1985 and 1986 engines (Prefix “18”) were produced with flat tappet cams. Hydraulic roller cams were first introduced in 1987 (Prefix “09”). These two cam types require different timing chain sets, because the hydraulic roller cams have a stepped nose like the LT1 engine as described later in this section. In 1992, a balance shaft was incorporated in this engine, which necessitated a third timing chain setup to drive both the cam and the balance shaft. The cam (Prefix “56”) in this balance shaft engine is also shorter than the earlier model and does not have a fuel pump lobe. Small Block V8 There are several varieties of small block engines currently in use in the aftermarket. Although they mostly use the same block, the cylinder heads are very different and require totally different camshafts. The valve arrangement in the heads is different, and therefore the lobe placement on the camshafts must coincide with the head you are using. The “54” is the first cam to completely stray from the original design. It is .300” larger in diameter. The nose of the standard early model cam “12” is very different from the later model hydraulic roller “08”. The nose of the hydraulic roller “08” is necked down to accommodate the cam retention plate. The “07” is an LT1/LT4 shaft which has a longer dowel pin and a center hole for the distributor. Be sure to check the diameter and depth of the hole in the front, as well as the length of the dowel pin. Standard Small Block Chevy -uses “12” Prefix This is the basic engine configuration found on all small blocks from 1955 until 1987, when Chevrolet introduced the roller cam. It’s important to note that the 1955-1957 versions require an oiling groove to be machined into the rear cam journal, but the camshafts are interchangeable. [font="verdana,
< Message edited by z28pete -- 11/16/2007 4:11:25 PM >
_____________________________
Pete
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
