Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
WANNA PUT 350 in, take 231 OUT, will computer & tranny work etc?
  Printable Version
Camaro Forums >> Camaro Models >> 2nd Generation >> V8 Tech >> WANNA PUT 350 in, take 231 OUT, will computer & tranny work etc? Page: [1]
Login
Message << Older Topic   Newer Topic >>
WANNA PUT 350 in, take 231 OUT, will computer & tranny ... - 1/1/2008 5:46:29 PM
75Guy
Score: 0
Status: offline
Hi, I guess I'm finally gonna give up on EVER finding a decent condition 231/3.8 V6 for our 80-81 Berlinetta Camaro, I've got a V8 and a TH350 trans I can swap in, just wondering what will have to be changed?  I assume the V6 computer wont work with a 350, do I HAFTA have a computer to run the gauges etc too?   I figured it would be easier to put in a non-computer 350 and go with that.
Also, I was told the 3 speed automatic behind my original V6 is NOT a TH350 even though the pan looks like one, no problem, I have an actual TH350 I can swap in, but: will drive shaft, and other stuff, etc. fit or not?
Mucho thanks for any and all info you can give me!
Post #: 1
RE: WANNA PUT 350 in, take 231 OUT, will computer & tra... - 1/1/2008 6:56:43 PM
Gorn
Score: 0
Status: offline
Gorn's photo gallery
Man for the life of me I am drawing a blank on a 80-81 computer. If it had one it was old 3C system all it really controled was the metering rods in the carb and some the timing control. To elimate the computer you just disconnect the 4 wire plug on the distributer jump a to c (I think) and install a no computer carb. It effects very little else on the car. I pretty sure there was only two trannys offered the th350 and the 200 metric. If I remember right the metric had the word metric pressed into the pan. Yow will have to swap out transmision anyway I pretty sure all the 3.8's back then where the Buick pattern so your 305 will not bolt up. Unless its one of those oddball duel pattern trannys I have seen a few times.
Sorry about the typos and mistakes I have a bad head ache. Hopfully some with a clear head will post for ya.
_____________________________
67 RS/SS, 350/4 speed, 12 bolt, Power top, Full gauges
Dingers Build Thread
(in reply to 75Guy)
Post #: 2
RE: WANNA PUT 350 in, take 231 OUT, will computer & tra... - 2/9/2008 6:09:56 AM
bowtie4ever
Score: 0
Status: offline
They had the screwed up computer controlled distributor, you do not need all that stuff, unless you are trying to keep in original type condition,(except with a V-8),the berlinetta is really not anything that is gonna go for 40,000 dollars in 10 years (no offense), I'd take it all out, run a hot small block, get a painless wiring harness (EASY to do), just so it will look stock, and stiffen the back end and have fun!!!!!
(in reply to Gorn)
Post #: 3
RE: WANNA PUT 350 in, take 231 OUT, will computer & tra... - 2/18/2008 7:26:32 AM
TurboBuickSix
Score: 0
Status: offline
Have you considered a 86-87 LC2 swap? That is the Turbocharged FI version of the same 3.8 you have,way more torque,alot less fuel consumption. If you could get a wrecked GN or T for a reasonable price and swap it all over it sure would make for a mean azz sleeper! I'm thinking of doing this with my 80' berlinetta someday but I have the 229,your lucky in that respect as it would be a drop in replacement for your 3.8.Good luck whatever you do!!
1986 Grand National
1980 Camaro V6 Berlinetta
(in reply to bowtie4ever)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 2nd Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
