Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
single turbo set up
  Printable Version
Camaro Forums >> Brand Review >> Nitrous, Super Chargers, & Turbos >> single turbo set up Page: [1]
Login
Message << Older Topic   Newer Topic >>
single turbo set up - 1/9/2008 3:16:00 AM
Twizted96Camaro
Status: offline
was wondering if turboing a v8 is same as a 4 banger? how much boost can a stock lt1 350 handle without changing any thing and were can i find turbo parts for a camaro??
Post #: 1
RE: single turbo set up - 1/9/2008 8:05:14 AM
ninetysixyenko
Status: offline
ninetysixyenko's photo gallery
i beleave it's around 7-9 PSI on stock internals. and for that much boost, prolly better getting a procharger, you can bolt it on yourself, then just get it tuned.
_____________________________
DC-Sport Header Back Exhaust, Injen SRI, AEM Under Drive Pulleys, B&M Short-Throw, Big Brake Kit, Torque Dampener.
5% Tint All Around, Halo''''s
(in reply to Twizted96Camaro)
Post #: 2
RE: single turbo set up - 1/9/2008 9:04:12 AM
badinfluenceRS
Status: offline
www.camaroz28.com has a sponsor that makes kits for pretty reasonable
1999 Camaro Z28 - LS1 / A4
(in reply to ninetysixyenko)
Post #: 3
RE: single turbo set up - 1/9/2008 3:33:03 PM
cbr600rx7
Status: offline
It depends a little bit on what kind of set up you want to run. Boost vs. compressor size also matters on how much boost you can run safe. The basic principles are the same for any gas engine the only thing that changes is how you chose to run and tune the set up. STS makes good affordable systems for the Fbody. The amount of boost you can run will also depend on if you’re running an Intercooler, fuel mods, and how much tuning you want to but into the set up. I strongly recommend having the LT1 dyno tuned for even low boost. It will make the engine run more efficient and can save you lots of pain latter on.
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO
RED 00
346 LS1 .60 trim, Methanol, Patriot duel springs, 228/234 114LSA, 3" empire Driveshaft, 15"prostars, TCI 4500 Stall.
Black 99
(3.8 DD) Whisper Lid, K&N, Magnaflow exhaust, 17"polished wheel
(in reply to badinfluenceRS)
Post #: 4
RE: single turbo set up - 1/11/2008 12:40:53 AM
Twizted96Camaro
Status: offline
thanks i just wanted to run low boost like shootin a 50 shot of nitrous but i can control the boost an i dont have to keep buy nitrous all the time... 5 to 7 pounds boost something noticeable but not crazy but thanks on the info man
(in reply to cbr600rx7)
Post #: 5
RE: single turbo set up - 1/11/2008 7:09:51 PM
cbr600rx7
Status: offline
You can notice as little as one pound of boost on a mild size turbo. It might not throw in back into the seat but it would add some performance. Running 7 pounds would be as far as I would push it if you don’t plan on running an intercooler. I would strongly suggest dyno tuning for any thing over 5 pounds. It would be a good idea to upgrade your fuel pump just to be on the safe side of things as well.
Turbo’s make power based on a few things the first being boost pressure. Obi sly the more boosts you run the more air your pushing into the engine. The second factor is the size of the turbo it’s self. A large turbo may move more air at a lower boost level vs. a smaller one but could take longer so spool and build pressure. The remaining factor is intake tempter. Turbo’s produce a lot of heat and as a result they cause large increases in intake charge tempters. Tempter increase more as you increase boost. If the temps get to hot it can lead to knocking and even detonation and heavy engine damage this is ware intercoolers come into play. However A large intercooler may increase cooling but can also increase lag as well plus they are not cheap as you well know.
Most v8s run a good size turbo vs. are 4 cylinder friends. Just because a turbo isnt running 18 pounds of boost doesn’t mean they are not making good power. STS claims a 120 horse power at the wheels increase on there none intercooler system at only 7 pounds of boost on the LT1 kit using a T04E 60-1 Garrett turbo and claim a 1.3 second increase in the 1/4. There LS1 kits claims 100 HP at only 5 pounds also none intercooler
< Message edited by cbr600rx7 -- 1/11/2008 7:14:14 PM >
RED 00
Black 99
Post #: 6
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Brand Review >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
