Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Poppin noise WTF
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V6 Tech >> RE: Poppin noise WTF Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: Poppin noise WTF - 2/26/2008 7:02:14 PM
z28pete
Status: online
z28pete's photo gallery
1)Your engine uses two (2) crank position sensors. 24X (high res) and 3X (low res)
The 24X sensor behind the front damper stabilizes spark timing from idle to around 2000 RPM. If this sensor is bad the idle speed will be affected, the spark control will default to the 3X sensor, but the MIL will not be lit. If the scanner said the High Res Sensor is bad, you need to fix the sensor problem in order to make the engine idle properly.
2)The 3X sensor midway on the passenger side of the block provided the reference signals to the ignition control module, and if this sensor is bad the car will not start.
3) Exhaust leaks will cause noise, but will not cause misfires.
4) Any vacuum leak will affect idle speed.
_____________________________
Pete
(in reply to 3.4CamaroCDOG)
Post #: 21
RE: Poppin noise WTF - 2/26/2008 7:10:53 PM
3.4CamaroCDOG
Status: offline
so if my car is misfiring at 3000 RPM wtf could that be cause it has no problems below 3000
its comin from the driver side of the engine
(in reply to z28pete)
Post #: 22
RE: Poppin noise WTF - 2/26/2008 7:20:32 PM
3.4CamaroCDOG
Status: offline
also it only happens when the car is cold
Post #: 23
RE: Poppin noise WTF - 2/26/2008 7:28:35 PM
nsbjim
Status: offline
I might be off, Sounds somewhat what I have experienced, it was ticking sound though that I would hear. Turned out to be a bad plug wire that the boot of it was barly touching the plug it self. When the car was at idle I would put my hand on each wire and think it was the number 5, which ever one is closet to the fire wall on the driver side and i could feel the ticking from the wire. snugged up the wire to the plug and the ticking noise stopped. Its a easy check if you haven't already.
NSBJIM
Post #: 24
RE: Poppin noise WTF - 2/26/2008 7:45:02 PM
3.4CamaroCDOG
Status: offline
i got new wires and they are on correct it was misfiring before i changed them
i dont really know wat to do :( i want my old camaro back
(in reply to nsbjim)
Post #: 25
RE: Poppin noise WTF - 2/27/2008 4:13:16 AM
02StanGT
Status: offline
02StanGT's photo gallery
I thought you said you had a code for crank sensor going bad? Maybe I misunderstood. Not sure how the EGR is set up on a 3.4. I've seen it a couple ways. On my mustang the EGR was mounted directly to the intake, and on my Camaro a pipe runs from the exhaust manifold to the EGR valve then another pipe to the intake. If it has pipes on either side, it depends on what side, as to if it can cause the high idle. Intake side, yes. Exhaust side, I doubt it. If your hole is on the exhaust side, that could be the source of your "popping" sound.
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF
1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies on the way :)
www.fquick.com/MrLogger
Post #: 26
RE: Poppin noise WTF - 2/27/2008 9:31:47 AM
jdog
Status: offline
make sure u check to see if your spark plug wires are getting spark to your coil u might have a bad one of those that happened to me about 5 months ago
>v6 muscle<
Post #: 27
RE: Poppin noise WTF - 2/27/2008 9:37:23 AM
3.4CamaroCDOG
Status: offline
this is wierd this morning after i idled my car down with the screw it isnt popppin anymore but ima do some test after school. ima seal the hole up in the EGR hose that connects to the intake and get my new exhaust friday
(in reply to jdog)
Post #: 28
RE: Pippin noise WTF - 2/27/2008 1:01:42 PM
z28pete
Status: online
quote:
ORIGINAL: 3.4CamaroCDOG
I thought you said that the car had idling problems and that the scanner showed a bad crank position sensor. As I said before, the crank sensor in front stabilizes the spark timing from idle to about 2000 RPM. The crank sensor on the side of the block provides spark timing at startup and at over 2000 RPM where the front sensor leaves off. If the side sensor is bad, the engine will not start, and if the front sensor is bad, the idle will be bad.
< Message edited by z28pete -- 2/27/2008 1:07:57 PM >
Pete
Post #: 29
RE: Pippin noise WTF - 2/27/2008 2:17:10 PM
3.4CamaroCDOG
Status: offline
that y im sayin i fixed the idle problem a lil
i adjusted it down with the idle screw and now that i found a small whole in my egr hose i think thats makin it idle the rest of the way
the car starts up perfect and now it is not misfiring anymore just once every 10 cranks
i scanner said crank signal shorten
Post #: 30
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 4th Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
