Poppin noise WTF
Login | |
Poppin noise WTF - 1/15/2008 2:29:52 PM
3.4CamaroCDOG
enough is enough im tired of this poppin noise i changed the spark plugs the oil and filter and i checked for intake leaks and there are none. But im still gettin this poppin noise i cant even get my car scanned at autozone or any auto place because they only scan 96 and up but wtf the 95 camaro 3.4 and 96 camaro are the same arent they? can someone give me a list of wat my problem could be? it is also revving real high at first start and in nuetral. do u want me to make a vid cause i can try?
RE: Poppin noise WTF - 1/15/2008 2:41:43 PM
02StanGT
Joined: 9/18/2005 From: Ft. Worth, TX Status: offline
'96 started the 3.8 era. No more 3.4. Also '96 started the OBD-II. '95 is OBD-I. Nothing is the same.
_____________________________
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF 1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies on the way :) www.fquick.com/MrLogger
RE: Poppin noise WTF - 1/15/2008 3:17:36 PM
Chappie99
explain the "poping" noise. From the exhaust tail pipes like a back fire?
"Boston, the greatest sports city in America" 99 Camaro V6 3.8 liter 231 C.I.D 2002 Ram Quad Cab 4X4 4.7 Liter 287 C.I
RE: Poppin noise WTF - 1/15/2008 3:20:53 PM
3.4CamaroCDOG
naw its from under the engine like on the driver side its annoying and draining my power when ever i step on it
RE: Poppin noise WTF - 1/15/2008 3:21:33 PM
3.4CamaroCDOG
*hood
RE: Poppin noise WTF - 1/15/2008 9:14:55 PM
Chappie99
sounds like a exhaust leak. Check your manifold to y-pipe connection. Possibly cracked exhaust manifold.
RE: Poppin noise WTF - 1/15/2008 10:39:52 PM
02StanGT
quote:
ORIGINAL: Chappie99 sounds like a exhaust leak. Check your manifold to y-pipe connection. Possibly cracked exhaust manifold. Word. Though in previous posts you said it sounds like misfiring. Also you said a couple spark plugs were white, which indicates a lean condition. Hence, as I answered in the other post, perhaps you have a few injectors that need cleaning...
