Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: help with decoding 67 RS/SS350
  Printable Version
Camaro >> Camaro Models >> 1st Generation >> SS/Z28 >> RE: help with decoding 67 RS/SS350 Page: <<   < prev  1 [2] 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: help with decoding 67 RS/SS350 - 1/16/2008 2:27:56 PM
MichiganMan
Score: 0
Status: offline
MichiganMan's photo gallery
without a vin stamp it will be a date correct engine here is some more info In that casting (3892657) a ME suffix stands for a small journal 327/ Auto trans.
In the same castings, the MS, MT, MU, and MV blocks were large journal and were 350's. GM just opened up the main journal on these to fit the larger 350 crank. These blocks were the L48 350's and were only used in the 67 Camaro SS. The 350 blocks are a lot rarer and cost more....
< Message edited by MichiganMan -- 1/16/2008 2:34:51 PM >
_____________________________
http://i3.photobucket.com/albums/y62/MDS59/69ss/mar31103.jpg http://s3.photobucket.com/albums/y62/MDS59/69ss/
(in reply to timinator)
Post #: 11
RE: help with decoding 67 RS/SS350 - 1/16/2008 2:44:12 PM
timinator
Score: 0
Status: offline
Very helpfull MM.
So is this statement true?
A 1967 with 327, regaurdless of the type of tranny can not be numbers matching car, Only a date correct car and a suffix matching car.
(in reply to MichiganMan)
Post #: 12
RE: help with decoding 67 RS/SS350 - 1/16/2008 2:49:01 PM
MichiganMan
Score: 0
Status: offline
quote:
ORIGINAL: timinator
Very helpfull MM.
if there is no vin that is correct some 327's also got a vin stamp if your luck this might be one of them
< Message edited by MichiganMan -- 1/16/2008 2:52:38 PM >
Post #: 13
RE: help with decoding 67 RS/SS350 - 1/16/2008 3:00:01 PM
timinator
Score: 0
Status: offline
We shall see.
I'm going to look at it in a few hours. Hopefully it has the vin stamp and not counterfiet restamp. I assume there's no way to tell the difference.
I will also look at the spedo cable location and the tach RPM range. I will post vin#'s tomorrow and maybe some pics.
Thanks for the help MM
Post #: 14
RE: help with decoding 67 RS/SS350 - 1/16/2008 3:01:23 PM
MichiganMan
Score: 0
Status: offline
quote:
ORIGINAL: MichiganMan
quote:
ORIGINAL: timinator
Very helpfull MM.
I stand corrected .........
In 1967, the 327 engines did not get the partial vin stamped on the engine or transmission. You should look for the cast dates and the build dates an all components. The 12 bolt codes for 1967 could also start with "Q" such as "QK" for 3:31 Posi. If the 327 is original and a 4 bbl carb., the stamp on the front of the engine would have a suffex of MK for a Nor car and ML for a Los car.
Post #: 15
RE: help with decoding 67 RS/SS350 - 1/16/2008 3:03:24 PM
MichiganMan
Score: 0
Status: offline
quote:
ORIGINAL: timinator
We shall see.
From what i just read if there is a vin stamp on it and it is a 327 it is a restamped engine if it matchs the vin since ALL 327 1967 engines didnt come with a vin stamp or it is a 68 and up motor
< Message edited by MichiganMan -- 1/16/2008 3:08:29 PM >
Post #: 16
RE: help with decoding 67 RS/SS350 - 1/16/2008 3:06:53 PM
MichiganMan
Score: 0
Status: offline
this is crazy must be your lucky day we are like in a fricken chat room here LOL that dont happen much here  You have a pm
< Message edited by MichiganMan -- 1/16/2008 3:17:05 PM >
Post #: 17
RE: help with decoding 67 RS/SS350 - 1/20/2008 9:26:37 PM
timinator
Score: 0
Status: offline
I check out the motor yesterday and something doesn't add up.
The casting number is correct for a 1967 "3897657" but the engine suffix is "MU" which is for a 350/295 1968 with AT.  A 1968 block should have a casting number of "3914678"
Does anybody know whats going on here?
Also all the numbers on the front pad are removed from an earlier rebuild, all but the suffix code "MU"
Post #: 18
RE: help with decoding 67 RS/SS350 - 1/21/2008 3:41:01 AM
MichiganMan
Score: 0
Status: offline
In the same castings, the MS, MT, MU, and MV blocks were large journal and were 350's. GM just opened up the main journal on these to fit the larger 350 crank. These blocks were the L48 350's and were only used in the 67 Camaro SS. The 350 blocks are a lot rarer and cost more.... I COPIED PASTE THIS FROM ABOVE POST
< Message edited by MichiganMan -- 1/21/2008 4:18:38 AM >
Post #: 19
RE: help with decoding 67 RS/SS350 - 1/21/2008 9:26:01 AM
timinator
Score: 0
Status: offline
so the motor is a 67 350/295hp suffix MU that is complete with what looks like the correct carb, intake & exhaust manifolds, heads, distributor etc....... I still need to varify the numbers. The car is an real RS and an SS350 clone.
BTW: I couldnt pass it up. I should have it in my garage wednesday!!!!!!!!
Thanks for all the help MM.
Post #: 20
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 1st Generation >> SS/Z28
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
