firebird69racer
Score: 0 Joined: 5/25/2003 From: San Bernardino,Ca Status: offline
This is what it says on one of the sites for a SS car. You may have discussed this as I have not read all your posts Frequently Asked Questions SS Camaro Q. Is my Camaro an SS? -OR- I want to know if this Camaro is a true SS? -OR- How can I tell if my Camaro was a true SS? Our Favorite: This Camaro has SS emblems on it is it an SS Camaro? (Below is a brief summary of some things to check but is by no means complete. Depending on the year, checking the VIN, RPO codes or Trim Tag codes will help determine whether a particular car is an SS or not.) A. The Chevy Camaro Super Sport, better known as the SS, was produced from '67-'72 and '96-2002. Basically, it was a performance package with some nice looks added to help identify them before you got to see their tail lights. Since the SS was a performance package, the engine is one of the most important parts of an SS Camaro. In most cases the original SS engine is required to identify the car as possibly being a true SS. Also, remember that having the original engine doesn't mean the rest of the car is still original. Check everything including dates, castings and partial VIN's. If the complete VIN says it was originally a 6 cylinder Camaro then you can guarantee it was not an SS so be sure to check the VIN. Unfortunately, these days it is so easy to fake almost everything on a Camaro - the more you know the better off you will be. Here is a good old saying that is never more true than for this ... if we had a nickel for every time someone said they had an SS Camaro (but did not) we would be filthy rich by now. Identifying a First Generation SS: From the looks of the emails we get on this subject we can sum it up by saying the best place to start to try to verify a first gen SS is by checking the engine codes and dates. We hope more people read this before buying a Camaro not after buying that so called SS. The standard engine in a '67 to '69 SS was a 350/295hp (300hp in '69). A big block 396 with either 325hp ('67-'69), 350hp ('68-'69) and 375hp ('67-'69). A first gen. SS either had a 350 or a 396 engine. Required power front disc brakes starting in '69. A 10 or a 12 bolt could be ordered with an SS. A/C was available on SS's unless the engine was 396/375hp. All first gen SS's could be ordered as a convertible. There is NO code in the VIN that recognizes an SS in any first generation Camaro. A '67 Camaro has a code on the trim tag for an SS and a late '69 Camaro had an "X" code on the trim tag to identify some SS's. The X11 code is the only exception to identifying a true '69 SS Camaro because the code also means a plain Camaro. Unfortunately there are no codes on a '68 Camaro to help identify an SS. A Protect-o-plate can be helpful in identifying a first gen. SS but be careful because there are places that make reproductions of both trim tag and protect-o-plate. The engine is very important to an SS Camaro but is necessary to identify all '68 and most '69 Camaros. Before emailing us in the hopes that we know some secret to identifying SS's check the engine codes at Engine Codes for SS horse power (HP) ratings see below. If the Camaro doesn't have the original engine then finding out whether it was an SS at one time just got that much harder and in most cases impossible. The only thi
_____________________________
Wade http://s198.photobucket.com/albums/aa291/firebird69racer/
