Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
help with decoding 67 RS/SS350
  Printable Version
Camaro >> Camaro Models >> 1st Generation >> SS/Z28 >> help with decoding 67 RS/SS350 Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
help with decoding 67 RS/SS350 - 1/15/2008 6:47:25 PM
timinator
Score: 0
Status: offline
I'm a newbe here and need a little help decoding.
I have a chance to purchase a nice 67 RS, maybe a SS350
The owner claims its a SS350 and claims to have the #'s matching block in his garage.
I have yet to see this block to varify the numbers. I'm not sure how to at this time but I am reseaching.
the trim tag reads as follows.
12A         0242
67-12637   LOS 10889
765-Z            R-R
W  2LGR          3SL
5Y
I thought it would need the 4P code to be a SS350.
It is said to have the correct 12 bolt (3.73) and 4 speed tranny but I havent varified the #'s. It does have PS/PB and multi-leaf springs, tach, console and gages.
What other tell tale sign should I look for to varify if its a true SS
Thanks
Post #: 1
RE: help with decoding 67 RS/SS350 - 1/15/2008 8:08:24 PM
Ircyklops
Score: 0
Status: offline
use these for verification...
http://www.68rscamaro.com/camfacts/
http://www.camaros.org/index.shtml
http://www.chevy-camaro.com/chevy-camaro-engine-codes.asp
http://www.teufert.net/carbs/4-barrel.htm
_____________________________
Hugger Orange X22 Convertible 4-speed SS396
(in reply to timinator)
Post #: 2
RE: help with decoding 67 RS/SS350 - 1/15/2008 8:56:43 PM
timinator
Score: 0
Status: offline
thanks.
It appears its not a SS because of the "4P" not indicaded on the trim tag.
I still want to varify the "original block" but I have a question or two.
To verify the "numbers match" is it simply matching the engine suffix (MS,MK etc) and block date code with the date code on the body?
Or is there a more presice way of matching numbers?
I need to make a decision on this car tomorrow before its advertized locally.
Its a very clean RS with a 383 (installed) and the original block (TBD).
The interior is 9/10. ext is 7/10. He wants $20K.
any help on decoding the drive train is appricated.
(in reply to Ircyklops)
Post #: 3
RE: help with decoding 67 RS/SS350 - 1/16/2008 3:43:29 AM
MichiganMan
Score: 0
Status: offline
MichiganMan's photo gallery
Partial VINs were also stamped on most engines and transmissions from 1967 on. Not all engines and transmissions in 1967 were stamped with partial VINs. Details and examples are shown in the Drivetrain Decoding section. However, be aware that clever counterfeiters can "restamp" these components by machining off the original stamp and creating a new one.
http://i3.photobucket.com/albums/y62/MDS59/69ss/mar31103.jpg http://s3.photobucket.com/albums/y62/MDS59/69ss/
Post #: 4
RE: help with decoding 67 RS/SS350 - 1/16/2008 3:50:32 AM
MichiganMan
Score: 0
Status: offline
In my opinion if it was a original 67 ss the asking price would be considerably more I do mean considerably more. Check the original engine stamping's Im betting they will point to a 327.It is possible to find a partial vin stamp on the pad passenger side front of engine  be sure you check the vin # make sure it was a v8 originally
< Message edited by MichiganMan -- 1/16/2008 3:54:52 AM >
(in reply to MichiganMan)
Post #: 5
RE: help with decoding 67 RS/SS350 - 1/16/2008 7:38:45 AM
timinator
Score: 0
Status: offline
Thanks Michiganman. thats what I need.
I will get the drivetrain #'s this afternoon.
The vin is #124377L125364.
I agree with you that chances are its a 327.
The seller is a retired state trooper who bought the car 10 years ago from a local muscle car dealer for quite a bit more the $20k. My bet it that dealer slapped on the SS badging and hood and called it a RS/SS.
BTW the 4 speed tranny is suposed to be #'s matching.
Can you answer three more questions please.
1)This car has multi-leaf springs. I read that 67's only came with a single leaf including the SS's. Is this true? If so this must be later year leaf spring.
2)I've read about a differance between standard and SS models in the firewall around the brake booster. What is the differance?
3)Where would the build sheet be located? Is it easy to get to?
Post #: 6
RE: help with decoding 67 RS/SS350 - 1/16/2008 1:07:44 PM
MichiganMan
Score: 0
Status: offline
quote:
ORIGINAL: timinator
1)   all 67 rears were mono springs including 12 bolt SS and Z28 cars. 2) is refering to where the spedo comes through the firewall...The L30 M20  used a Saginaw 4 speed transmission. The Saginaw had the speedo cable on the driver's side, the cable ran thru the firewall very low, just above the dimmer switch, this is the same location as an automatic trans car.A Muncie trans equipped Camaro (SS M20) would have the spedo cable running thru the firewall just above the throttle lever and it attaches to the passenger side of the transmission.3)Los built cars sometimes have buildsheet under the gas tank's nor cars dont.this is a los car
Post #: 7
RE: help with decoding 67 RS/SS350 - 1/16/2008 1:38:14 PM
timinator
Score: 0
Status: offline
thanks again MM.
could you help me with one more question pretaining to the potential original block.
I read that on 67's partial vin's were added to the block ie "2L123456" for SS and Z28 only and 327's did not get the partial vin. If this is the case how would I verify the matching number block other then the date code and engine suffix?
I'm anticipating this block to be 327.
Post #: 8
RE: help with decoding 67 RS/SS350 - 1/16/2008 2:10:40 PM
MichiganMan
Score: 0
Status: offline
it won't be a '67 350 engine unless it has a '67 VIN letter stamp at the end of the long VIN number string on the deck pad!
Post #: 9
RE: help with decoding 67 RS/SS350 - 1/16/2008 2:16:23 PM
timinator
Score: 0
Status: offline
I understand MM.
But how is a 327 matched to a car without the partial VIN on the pad?
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 1st Generation >> SS/Z28
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
