Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Fuel Injectors
  Printable Version
Camaro >> Brand Review >> Computer & Fuel Systems >> Fuel Injectors Page: [1]
Login
Message << Older Topic   Newer Topic >>
Fuel Injectors - 1/20/2008 9:03:10 AM
3.4CamaroCDOG
Status: offline
ok so ive been running my gas low and lately my car has been having problems starting and misfiring. could this be my fuel injectors?
cam i just take them off and clean them?
Post #: 1
RE: Fuel Injectors - 1/20/2008 10:12:02 AM
z28pete
Status: online
z28pete's photo gallery
Check the ignition stuff before messing with the injectors. You can try cleaning them by using injector cleaner in your gas tank, or have them professionally cleaned.
_____________________________
Pete
(in reply to 3.4CamaroCDOG)
Post #: 2
RE: Fuel Injectors - 1/20/2008 8:08:53 PM
3.4CamaroCDOG
Status: offline
i did
i put in new plugs and wires
got my ignition coils checked they were good
everything ignition wise is good
i put cleaner in......... am i suppose to run it low with the cleaner?
could it be the fuel filter?
im really lost
(in reply to z28pete)
Post #: 3
RE: Fuel Injectors - 1/29/2008 2:03:07 AM
94CamaroSFI
Status: offline
94CamaroSFI's photo gallery
I dont understand how you manage to run a 3.4 camaro low on gas and still drive it.. If im under a half a tank, it's nearly empty. You are slowly leading up to far worse problems by running it low on gas, (Ie Burning up your fuel pump)... Keep it on full instead of 10 bucks here and there, I would replace the fuel filter. I had a bad misfire that was supposedly an injector, and it was in fact the coil packs. Dont worry though anything off a 3100 engine (Lumina/ Monte) among others all have the same setup though youll have to use your bracket. I think i paid 25 bucks for a set of coils. And It runs so much better.  I would recommend putting at LEAST 89 octane,preferably 91-94 octane, regardless of what the owners manual suggests.. 87 octane runs like **** in the 3.4.
and while you are at it.. SEAFOAM IT  (6-7 dollars at any auto store
http://wiki.ls1tech.com/forums/showthread.php?t=534376
I did it via the brake booster line and put a can in my gas tank. Ive yet to do the oil.  I just did an oil change on mine so I might do that in about 2600 miles [to the oil]
I can almost guarantee Fuel Filter + change Coil Packs and the misfire will be gone..
Out of Curiousity what Plugs are you using? Id recommend some sort of dual platinums since these have DIS ignition systems (3 plugs fire twice in a row, Which fouls up those 3 faster than the others.
< Message edited by 94CamaroSFI -- 1/29/2008 2:09:55 AM >
94 Camaro 3.4L Manual Transmission, CAI, Magnaflow Exhaust
91 3.1L RS manual, CAI, 3.42 Rear end gears, Catback
Post #: 4
RE: Fuel Injectors - 1/31/2008 9:40:22 AM
3.4CamaroCDOG
Status: offline
i was exzagerating i dont run it that low
im using AC Delco plugs
i got the coils checked and they were ok but i am goin to change the fuel filter
can u give me a tutorial or sumthin please
where can i find cheap new coil packs?
and are filters at walmart good to use?
(in reply to 94CamaroSFI)
Post #: 5
RE: Fuel Injectors - 2/7/2008 6:07:25 PM
camaro maniac
Status: offline
hi, running your car on low gas all of the time is a ver bad thing, you want to run it from about a half a tank to a quarter of a tank at the least, sometimes, actually all of the time, the gas in the tank is what the pump uses to lubricate it and keep it cool, running it on low for a long period of time could cause the pump to burnout, the thing that you are feeling could be the fuel pump starting to call it quit, i wouldn't run your tank of E much longer and see if you can bring back the pump, good luck, let me know what happens
Post #: 6
RE: Fuel Injectors - 2/9/2008 11:21:28 PM
3.4CamaroCDOG
Status: offline
i found out that i have a really bad Exhaust leak which is causing the poppin noise at higher RPM i am goin to get a flowmaster exhaust when i get paid
(in reply to camaro maniac)
Post #: 7
RE: Fuel Injectors - 2/10/2008 7:41:30 PM
z28pete
Status: online
Fixing an exhaust leak is not going to do much for your hard starting problem and misfire.
Pete
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Brand Review >> Computer & Fuel Systems
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
