RE: Camaro engine code information
Login | |
RE: Camaro engine code information - 3/10/2008 9:20:13 AM
1stGenFan
Score: 0 Joined: 3/10/2008 Status: offline
I picked up one of these short blocks at a local swap meet this weekend & went looking to see what I could find on it. I could not find a 3959512 block listed in any of the Chevrolet by the Number series. So I did a search & found this post. Here's the details: Original shortblock only has been decked so there are no stamped numbers left to read. I should mention here that the guy that I bought it from had torn it down & bored & decked the block. He insisted that the block & crank appeared to have been together all of the engines life. It is a 2-bolt block. Block casting date is I*20*8 which should be September of 1968. 1969 model year. The guy had been told that it was an early 327. But it is a large journal engine. And it is not an early 327 date. Crank casting number is #1182. And that is where it got a little more interesting. According to Chevy by the Numbers, the crank is listed only as a 1967 350/295, forged steel, large journal, aaaaaaaaannnnnnnnnnnnddddddddddd (drum roll) Z28 Camaro only! So at the very least Chevy by the Numbers has a missprint somewhere here. Anyone else have any thoughts on it?
RE: Camaro engine code information - 5/19/2008 6:31:09 PM
Trbomike
Score: 0 Joined: 5/19/2008 Status: offline
I'd like to share some information on a 3959512 motor that I have in my possession and have known since 1971. It is a CE motor and was put in my 65 Nova in very late 69 or early 70 to replace the fried 327/300. It is a factory 2 bolt small journal, casting date J29, canister oil filter, and it came with domed pistons. It is not a Chevy II block. I know this because I bought the car from the 2nd owner in Dec. '71, who had to replace the motor @ ~58,000 miles. I got the car with ~73,000 miles on it. Now I'm starting to wonder if it's a 327 (that's what I was told) or what? I apologize for being off topic (Nova/Chevy II), but I have been searching the web for information on this motor and came across your forum. Mike
