RE: distributor vacuum advance line hook up
Login | |
RE: distributor vacuum advance line hook up - 5/6/2006 11:35:59 PM
sewerrat
WOW Sick, great explanation! That was one hell of a Advance timing 101. I've never heard of adjusting intial timing that way, but I'm gonna do it that way from now on. So back to my first question is I should hook it up to constant manifold vacuum after adjusting, right? Thanks for the input everyone, mike
RE: distributor vacuum advance line hook up - 5/7/2006 12:53:03 PM
SickSickSick
Joined: 3/13/2006 From: Orange, Texas Status: offline
Constant Vacuum. Use The Vacuum Port At The Front Right Base Corner Of The Carb. Sick
_____________________________
RE: distributor vacuum advance line hook up - 5/8/2006 5:07:32 PM
z28pete
quote:
So Since My Cam Duration Is Over 300 ... You Think I Would Be Better Off Without Vacuum Advance? Sick With your cam you should be able to disable the vacuum advance and just work with the mechanical adavance, especially if are using the car mostrly for racing. I know you don't like to use timing lites, but you can use one to see if the vacuum advance is really doing anything. With engine idling, the timing lite connected and aimed at the timing marks, pull the vacuum adavance hose from the distributor and keep it from sucking air. If the timing changes, then the vacuum advance is actually doing something. if not the vacuum advance is just going for the ride. In any case, at WOT the vacuum advance is out of the picture.
Pete
RE: distributor vacuum advance line hook up - 5/8/2006 10:03:59 PM
SickSickSick
Kewl. I Have A Whole Assortment Of Advance Springs I'm Gonna Play With As Soon As Get Some Consistant Runs. By The Way ... Thanks For The Strut Advice. I Bought A Set Of Lakewood 90/10's made A Big Difference. My Stock Struts Were Completely Flat. Sick
