Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
distributor vacuum advance line hook up
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> V8 Tech >> distributor vacuum advance line hook up Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
distributor vacuum advance line hook up - 5/4/2006 3:06:49 AM
sewerrat
Status: offline
Ok, It's been a long time since I played with a vacuum advance distributor and I need a refresher from you guys. I'm working on a friends 67 camaro with a 350. It's got an later HEI dist, edelbrock performer intake and carb. Do you hook up the dist. vac line to constant vacuum or port vacuum? I'm confused because I'm getting pros and cons on both hook ups. I'm told to connect to constant vacuum (vacuum at idle) so it will advance much faster but there is a chance of detonation. Then I'm told to connect to port which (will only send vacuum at higher rpms) so the advance will happen only on higher rpms but less chance of detonation. Any inputs are greatly appreciated. Thanks
Post #: 1
RE: distributor vacuum advance line hook up - 5/4/2006 3:10:24 PM
SickSickSick
Status: offline
SickSickSick's photo gallery
I Have Always Used Constant Vacuum. For Me It's Easier To Get The Timing Dialed In. Sick
_____________________________
(in reply to sewerrat)
Post #: 2
RE: distributor vacuum advance line hook up - 5/4/2006 5:11:33 PM
SLJ2137694
Status: offline
quote:
ORIGINAL: SickSickSick
How is it easier to get the timing dialed in? No matter where it is connected to you still need to disconnect the vacuum advance.
Retired and Loving It!!!
Steven L Jones
33 years with General Motors Product Service Engineering.
A.S.E. Certified
(in reply to SickSickSick)
Post #: 3
RE: distributor vacuum advance line hook up - 5/4/2006 6:13:02 PM
SickSickSick
Status: offline
I Adjust My Timing Using A Vacuum Gauge ... And No I'm Not The Only One ... Timing Lights Are For Rookies ... LOL ... Sick
< Message edited by SickSickSick -- 5/4/2006 6:27:47 PM >
(in reply to SLJ2137694)
Post #: 4
RE: distributor vacuum advance line hook up - 5/5/2006 3:22:04 AM
sewerrat
Status: offline
Hey Sick, How do you adjust timing with the vac. gauge? Do you tune it to get the highest vacuum? Do you disconnect vac. source while adjusting? Should I still try to keep my maximum advance at around 36 deg. total? Thanks
Mike
Post #: 5
RE: distributor vacuum advance line hook up - 5/5/2006 3:48:18 PM
SickSickSick
Status: offline
My Cam Has Such A High Duration 307 @ .050 That It Doesn't Have Near Enough Vacuum At Idle To Advance The Distributor. If Your Running A Stock Motor On Constant Vacuum, You Will Need To Disconnect Vacuum Advance To Time It With A Vacuum Gauge. I adjust For Maximum Vacuum Then Back Off Two Degrees. I Usually Can Make The Two Degrees Back By Adjusting Idle Mixture. I'm Not Sure I Know What Your Asking About Disconnecting The Vacuum Source? Sick
Post #: 6
RE: distributor vacuum advance line hook up - 5/5/2006 8:17:41 PM
z28pete
Status: online
z28pete's photo gallery
The purpose of vacuum advance is to get additional spark advance on top of that provided by the mechanical advance in order to maximize fuel economy. At part throttle, when the manifold vacuum is high the spark is advanced, while at WOT when the manifold vacuum is low there is no vacuum advance provided. At WOT all advance is provided the mechanical advance mechanism. If you have a hot cam, the vacuum is usually too low to cause any additional spark advance and things work better if it is disabled. The vacuum advance should always be disabled when setting the timing with a timing light.
< Message edited by z28pete -- 5/5/2006 9:01:59 PM >
Pete
Post #: 7
RE: distributor vacuum advance line hook up - 5/6/2006 1:09:50 AM
SickSickSick
Status: offline
So Since My Cam Duration Is Over 300 ... You Think I Would Be Better Off Without Vacuum Advance? Sick
< Message edited by SickSickSick -- 5/6/2006 1:11:30 AM >
(in reply to z28pete)
Post #: 8
RE: distributor vacuum advance line hook up - 5/6/2006 5:00:15 PM
SLJ2137694
Status: offline
I don't understand, you adjust the carb idle mixture and that changes your timing back 2 degrees? Please explane.
Steven L Jones
A.S.E. Certified
Post #: 9
RE: distributor vacuum advance line hook up - 5/6/2006 9:29:10 PM
SickSickSick
Status: offline
Sorry For The Confusion Sometimes I Don't Use The Correct Terms Assuming Everyone Knows What I'm Talking About. First Of All We All Know That Timing Advance Matches The Ignition Timing To The Burning Rate Of The Fuel And The Speed That The Engine Is Turning. Many Factors Effect The Rate Of Fuel Burn. Cylinder Pressure, Vacuum , Amperage, Fuel Octane, Air/Fuel Mixture, Temperature, Cubic Inches, Spark Plug Positioning, Air Flow Turbulence, Load, And What Not. ALL Engines Will React Differently To This Conditions. Even More So With Engines Using Aftermarket Parts Such As Cams. If You Relyed On A Timing Light Without Factoring In All The Other Conditions, You Would Be Doing Yourself and Your Engine A Diservice. Vacuum Guages Can Be Used As Well To Adjust Timing As Long As You Remember All The Conditions That Effect Ideal Engine Timing. Vacuum Gauges Are Set Up In Units Of Measure Called "Inches Of Mercury". I Have Found When Using A Vacuum Guage To Adjust Timing, That The Point Of Most Vacuum Is To Far Advanced For Your Engine To Run Properly. Why? Because Of All The Other Conditions Which Effect Rate Of Fuel Burn. It's Not Completely Accurate. Nevertheless I Have Found That If ( For Instance ) Your Point Of Most Vaccum Was 15 Inches Of Mercury And You Retard Your Distributor ( Normally Just A Degree Or Two ) Just Enough To Bring The Inches Of Mercury Down To 13, The Two Inches Of Mercury Can Be Regained By Adjusting Idle Mixture. Why? Air/Fuel Mixture Effects Rate Of Fuel Burn Which In Turn Effects Amount Of Vacuum. I Have Found Using This Method Can Get You Pretty Close To Ideal Ignition. Why This Much Concern For Two Degrees Of Mercury? Vacuum Effects Rate Of Fuel Burn. This Is My Own Expeirence. I Only Use A Vacuum Guage When I'm Trying To Remove A Dead Spot In Acceleration And What Not. The Best Gauge I Have Found For Timing Is My Hand On Top Of The Breather Cover. It's Very Easy To Feel Premature Or Post Detonation If You've Done It A Thousand Tmes. Sick
< Message edited by SickSickSick -- 5/6/2006 9:45:14 PM >
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 3rd Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
