Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
new owner help
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> IROC/Z28 >> new owner help Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
new owner help - 1/27/2008 6:01:36 PM
stock86
Score: 0
Status: offline
im new to the wold of chevys. i bought a 86 camaro z28 and fell in love. its only down fall is it has an electronic carborator that tends to give me trouble. whats a fairly cheap way to eliminate this system? please help
Post #: 1
RE: new owner help - 1/27/2008 6:37:51 PM
Jr. Mechanic
Score: 0
Status: offline
Jr. Mechanic's photo gallery
Just buy a holley or edelbrock carb to replace it, the wires don't need to be hooked up with the after market carb. Here is what I suggest:
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_974085_-1_10271
600cfm model.
_____________________________
Jr''''s Rides:
1983 Camaro Z28, 1993 Jeep Grand Cherokee, 1997 Plymouth Neon
(in reply to stock86)
Post #: 2
RE: new owner help - 1/29/2008 11:08:04 AM
stock86
Score: 0
Status: offline
if i get a new distributor will that eliminate the computer completely? and is it best to replace the intake as well
(in reply to Jr. Mechanic)
Post #: 3
RE: new owner help - 1/29/2008 9:03:23 PM
85Z28racer
Score: 0
Status: offline
I have a 85 z and I dont have my computer in it anymore I never had the wiring redone and it still runs if I remember correctly The computer does not run the distributor like it does in the newer cars
Post #: 4
RE: new owner help - 1/29/2008 10:06:07 PM
MadMikeZ28
Score: 0
Status: offline
The computer does control the distributer. It takes care of the advance. It would also need to have a signal from the TPS to work proper. Just a good rebuild and properly adjust and the Q-jet works great. All it has is a TPS to tell the computer of its position and a Mixture Control Solenoid that adjust the A/F at idle and part throttle.
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to 85Z28racer)
Post #: 5
RE: new owner help - 1/30/2008 12:27:20 AM
apsolus
Score: 0
Status: offline
dont try and convert over to old school youll only end up regreting it.  just find the problem and fix it.  a computer is much more advanced than a spring, dont you think?
(in reply to MadMikeZ28)
Post #: 6
RE: new owner help - 1/30/2008 1:25:06 PM
85Z28racer
Score: 0
Status: offline
True, it may control all of that but why would there be a vacum advance on it as well????? My car was originally a 305 tpi I have changed the motor to a 350 carb (and will be changing it again soon) but I never messed with any of the wiring to the distributor or for that fact anything (as long as you dont concider cutting the power to the fuel pump messing with the wires) now there is alot that is left loose but the distributor that was in the 350 was the original one that came in the 305 unless someone changed it before I got the car. I had to change it because the mechanical and vacum advances were froze solid. Wish I knew how that happened but the car is the same as far as wiring for right now
I will be going back and stripping the car down and I will rewire the entire car to free it up of all the wires soon but will be going back with fuel injection but dont know which one I want yet
Post #: 7
RE: new owner help - 1/30/2008 6:18:30 PM
MadMikeZ28
Score: 0
Status: offline
The distributer with the vacuum andvance did not go to the 305 TPI.
Post #: 8
RE: new owner help - 1/30/2008 6:29:40 PM
stock86
Score: 0
Status: offline
can i make it tuned port injected or is that not fesable
Post #: 9
RE: new owner help - 1/30/2008 7:18:11 PM
MadMikeZ28
Score: 0
Status: offline
quote:
ORIGINAL: stock86
You just have to get everything that goes with it. Computer, harness, etc.
If you have no smog type inspection then check out the holley or edelbrock injection units like on summitracing.com
Oh and one thing to look out for is if you have the center bolt valve covers then look at the center bolts on the intake. Do they go straight down or are they at the same angle as the rest. If you went after market injection you would have to make sure the manifold will bolt to the heads or you would have to modify the manifold some.
< Message edited by MadMikeZ28 -- 1/30/2008 7:24:49 PM >
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 3rd Generation >> IROC/Z28
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
