RE: Closest to HP numbers gets a prize!
Login | |
RE: Closest to HP numbers gets a prize! - 3/3/2008 12:22:28 PM
esteinmaier
I figure it's time for a little update. The motor is together, but I keep having to wait for piddly little parts to come in to put it all together. Right now, I'm in the process of putting together the transmission. I'm adding a torque-biasing gear type limited slip differential (Wow, that's a mouthful.) The bearing preload is off in the direction of interference, so I have to tear all kinds of stuff up to get it together properly. As of now, I hope to have the engine in the car on Thursday, although it may be Sunday, seeing as I never have enough time off of work, and if I can't find a couple seals locally, I'll have to order them.
_____________________________
04 Dodge Neon SE 2.0L SOHC 12.5, 117mph (Note to self: Buy a clutch that holds power...)
RE: Closest to HP numbers gets a prize! - 3/3/2008 12:24:41 PM
ninetysixyenko
hope you get it together! we have alot of HP numbers here!
DC-Sport Header Back Exhaust, Injen SRI, AEM Under Drive Pulleys, B&M Short-Throw, Big Brake Kit, Torque Dampener. 5% Tint All Around, Halo''''s
RE: Closest to HP numbers gets a prize! - 3/3/2008 4:32:11 PM
95 5speed
my guess is......362.21576319 HP yea im gettin technical
RE: Closest to HP numbers gets a prize! - 3/3/2008 8:15:43 PM
itcantbestephen
He was already making 240whp with his old setup, if I'm not mistaken.
1993 2dr Yukon 4x4
RE: Closest to HP numbers gets a prize! - 3/3/2008 10:32:27 PM
red94v6
ehh.... I think ill throw one out. is 402 at the crank taken? if that is then gimme 390 whp taken?
2000 Firebird 3.8 5-speed
RE: Closest to HP numbers gets a prize! - 3/4/2008 8:25:19 AM
cbr600rx7
Joined: 5/1/2007 From: Fort Brag NC (some where in iraq) Status: offline
What kind of 16G are you runing and what type of intercooler. I would say around 270 horses If i am reading ever thing right on a real street boost pump gas level. 1680cc Bosch fuel injectors? Is that correct ??????
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO RED 00 346 LS1 .60 trim, Methanol, Patriot duel springs, 228/234 114LSA, 3" empire Driveshaft, 15"prostars, TCI 4500 Stall. Black 99 (3.8 DD) Whisper Lid, K&N, Magnaflow exhaust, 17"polished wheel
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
