Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Closest to HP numbers gets a prize!
  Printable Version
Camaro >> Racing / Recreational >> Street/Strip >> RE: Closest to HP numbers gets a prize! Page: <<   < prev  3 4 [5] 6 7   next >   >>
Camaro Forums Sponsor
Street/Strip Forum Sponsored by MagnaFlow.
Login
Message << Older Topic   Newer Topic >>
RE: Closest to HP numbers gets a prize! - 3/13/2008 8:42:20 PM
itcantbestephen
Status: offline
itcantbestephen's photo gallery
Awesome man, I can't wait to see those numbers!
_____________________________
1993 2dr Yukon 4x4
(in reply to esteinmaier)
Post #: 41
RE: Closest to HP numbers gets a prize! - 3/16/2008 12:39:15 PM
esteinmaier
Status: offline
esteinmaier's photo gallery
Update:
I started the car for the first time last night.  I'm very new to this new MS2 chip installed in the standalone, so although I got it running, it's not running very good yet.  I need to change the oil out to flush out the assembly lube, and figure out what I can do to get the fuel tables at least somewhat stable.  I threw in 440cc injectors just to figure out the new software without having to also tune injector P&H times, etc.  So tonight, I should be able to tune it at least good enough to get on the road and learn the software, and then put the big injectors in later on in the week and just scale the tune back and get high boost tuned.  The project is finally coming to a close, and I'm counting down the seconds until I get to boost her for the first time.
Edit:
Drove her to the grocery store last night.  Now I've got enough run time on it that I'll change out the oil.  The tune is still pretty poor, but I'm working on getting the curve to where it needs to be so I can pop in the bigger injectors.  Thursday, I'll have most of the day to play with it, so I should have at least 2.5 BAR tuned in.  Then it's time to schedule dyno time to dial in up close to 3 BAR.
< Message edited by esteinmaier -- 3/17/2008 8:12:01 AM >
04 Dodge Neon SE 2.0L SOHC
12.5, 117mph
(Note to self: Buy a clutch that holds power...)
(in reply to itcantbestephen)
Post #: 42
RE: Closest to HP numbers gets a prize! - 3/18/2008 8:04:18 PM
itcantbestephen
Status: offline
Any guesses on the numbers yet?
1993 2dr Yukon 4x4
Post #: 43
RE: Closest to HP numbers gets a prize! - 3/19/2008 4:48:17 AM
esteinmaier
Status: offline
Well, now I broke the charger cable for my laptop, so I can't even tune it until the replacement gets here.  But it's ready to drive.  My guess?  I'd have to say my guess is 380.  I'd like to say 400, but I think that's a bit optomistic.
12.5, 117mph
Post #: 44
RE: Closest to HP numbers gets a prize! - 3/19/2008 6:37:55 AM
itcantbestephen
Status: offline
Either way, I bet that things going to be a rocket once you get it dialed in. How much does it weigh as it sits?
1993 2dr Yukon 4x4
Post #: 45
RE: Closest to HP numbers gets a prize! - 3/19/2008 9:07:24 AM
esteinmaier
Status: offline
Not sure, but it was 2350 with most of the interior left in it.  During the engine build, I removed the remainder of the interior, with the exception of the dash, removed power steering, removed the windshield sprayer and all associated equipment and lines, removed the heater lines (I still have to pull the core out, but that's quite a job in itself) and went to town with a sawzall on the rear deck seeing as I don't have a stereo in it.  Also pulled the tar paper off the floor, and cut out unnecessary wiring.  It's still a job in progress, but I think I probably have it down to around 2150-2200.  I still have a bunch of evap equipment to remove, as well as some more unnecessary sheet metal that used to retain cosmetic amenities, but I should have it down to 2000, or very close to it once I'm done pulling and sawing everything else out that I don't need.
I'm counting down the moments until I can bring it out on the open road and tune it.  Heck, I'd even settle for low boost at this point I'm so anxious to take it out.  Now it's time to see if the fuel system is up for the task.  With only a walbro 255lph pump, it's going to be close, but I have a fuel pressure accumulator/damper on the way that should help keep pressure in the rail up at torque peak.
12.5, 117mph
Post #: 46
RE: Closest to HP numbers gets a prize! - 4/1/2008 8:26:51 PM
itcantbestephen
Status: offline
Am I the only one anxious to see these numbers?
1993 2dr Yukon 4x4
Post #: 47
RE: Closest to HP numbers gets a prize! - 4/1/2008 8:28:28 PM
02StanGT
Status: offline
02StanGT's photo gallery
I think a few of us are, though we all know this stuff takes time.
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF
1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies on the way :)
www.fquick.com/MrLogger
Post #: 48
RE: Closest to HP numbers gets a prize! - 4/1/2008 8:33:17 PM
evilkal
Status: offline
Well then I'll throw in a number since you haven't gotten a dyno in yet... And I say 384 hp =P
(in reply to 02StanGT)
Post #: 49
RE: Closest to HP numbers gets a prize! - 4/2/2008 4:52:52 AM
esteinmaier
Status: offline
Sorry about taking so long y'all.  The engine runs like a champ, but the transmission blew up.  I also beefed it up at the same time in an attempt to actually get traction before 4th gear, but the differential was bad, and destroyed the trans in 1/2 mile.  I have another one, but working close to 60 hours a week doesn't leave much time for installing it.  Hopefully I can get the car back on the road tomorrow so I can start tuning.
12.5, 117mph
(in reply to evilkal)
Post #: 50
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Racing / Recreational >> Street/Strip
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
