RE: Closest to HP numbers gets a prize!
Login | |
RE: Closest to HP numbers gets a prize! - 4/17/2008 9:07:45 AM
nzink
i cant wait to see these dyno numbers. Have you desroyed any american muscle on the street yet?
_____________________________
1985 Z28 13.0 @ 106 350 bored .030, Holley 650 double pumper, holley intake, Dart Heads, Hooker short tube headers, stock exhaust -cat, 700R, 3.42 posi
RE: Closest to HP numbers gets a prize! - 4/18/2008 9:14:31 AM
itcantbestephen
I'm sure that Vette owner was, uh.. proud.. too!
1993 2dr Yukon 4x4
RE: Closest to HP numbers gets a prize! - 4/21/2008 7:35:18 AM
esteinmaier
Well, I borrowed some slightly larger injectors from a friend. Somewhere around 570cc. With the e85, it's giving me a 90% duty cycle at 7100RPM at 18psi of boost and 75psi of fuel pressure. My gearing is very long, with 1st bringing me close to 40mph, 2nd to 66, 3rd to 107. The car liquifies the tires in 2nd, and gives squeaks from the tires as it hunts for traction in 3rd. I'm probably making in the vacinity of 330 ft/lb and 300 hp at this point. I'll make another 7psi or so of boost once I solve the riddle of making the standalone successfully read RPM with big injectors. Probably the most fun part of driving the car now, besides the obvious having gobs of power in a beer canned compact, is that I've got the scramble boost function of the boost controller run through a switch in the dash. I run 10psi in 1st and 2nd gear, and once I get shifted into 3rd, I punch the button and it shoots up to high boost. It's almost like a nitrous button, it's so vicious once it hits the higher boost numbers. Anyone in the NW suburbs of Chicago want a ride?
04 Dodge Neon SE 2.0L SOHC 12.5, 117mph (Note to self: Buy a clutch that holds power...)
RE: Closest to HP numbers gets a prize! - 4/21/2008 7:38:35 AM
SpecterGT260
 Black Stig FTW Posts: 4225
^^^ there seem to be alot of us in the midwest. chicago wouldnt be a bad meet spot
quote:
ORIGINAL: BigNic if she offers to shift for you its on..... http://www.camaroforums.com/m_109346/mpage_1/key_/tm.htm#
