Closest to HP numbers gets a prize!
Login | |
Closest to HP numbers gets a prize! - 1/30/2008 5:13:25 PM
esteinmaier
OK, guys. I'm in the process of completing the neon build. After the build, I'll do a 1-day break in, and then take it to the dyno. The contest is this: After I dyno the car, I will be posting the dyno chart. Post your guesses as far as WHP numbers in this thread. I will keep track of them in this post, and edit the post to keep the changes. Dyno will be run on a DynoJet Dyno, at Chicagoland elevations. You may change your guess as many times as you want to, however, the last one before I post the dyno sheet will be the one that sticks, and all other guesses are thrown out. You probably have about 3 weeks before I can get it all finished and dynoed, so guess away. I'll try to answer any other questions about the build if I haven't provided enough information for an accurate estimation. The person that guesses closest to the actual numbers I dyno gets their choice of a 1GB MicroSD memory card, a car charger for their phone, or a leather phone case. I work for an AT&T store, so I will order the right one to fit your phone, regardless of the carrier. Details of the build: 04 Dodge Neon 2.0L SOHC Engine Bottom End: Stock bore Eagle forged rods Wiseco forged pistons @ 9.2:1 compression Top End: Stock head Magnum (Neon R/T) Camshaft Stock lifters, valve springs, etc. Turbo: Mitsubishi 16G turbo (Same specs as the turbo distributed by Hahn Racecraft) 3" downpipe Gutted cat (Aubrey, this one's for you) 2.25" midpipe to exit (No muffler) Fuel: 1680cc Bosch fuel injectors Aeromotive 1:1 FPR Walbro 255LPH Fuel Pump e85 fuel Management: Megasquirt MS2, V3 board, running fuel and spark AEM TruBoost electronic boost controller All other mods are either for monitoring, chassis, or drivetrain, and have no bearing on the final HP number. I'm not responsible if I forgot to mention something. If I remember something I've forgotten, I'll add it. ninetysixyenko - 372 SilverBullet5 - 362 robmnrd - 388 armynatguard18 - 338.7 rockin85 - 375 SpecterGT260 - 376 (First) GRIFF - 305 95slvrZ28 - 342 itcantbestephen - 370 aleksandr - 376 STIC5 - 298 buckfever - 398 nzink - 404 98ss4REAL - 290 95 5speed - 362.21576319 Duffman - 240 red94v6 - 402 cbr600rx7 - 270 evilkal - 384 96WhiteLightnin - 366
< Message edited by esteinmaier -- 4/3/2008 6:06:38 AM >
_____________________________
04 Dodge Neon SE 2.0L SOHC 12.5, 117mph (Note to self: Buy a clutch that holds power...)
