Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
V8 convertion Questions
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V8 Tech >> V8 convertion Questions Page: [1]
Login
Message << Older Topic   Newer Topic >>
V8 convertion Questions - 1/30/2008 5:56:29 PM
dodge destroyer
Score: 0
Status: offline
I have found a 1994 3.4L camaro for $1000. I wanted a z28 but to much money. Would this be a good doner car for a lt1 or ls1? and how much work would I be looking at? It has a 5 speed tranny would it bolt up to a V8 or would I need differnt bellhousing?
I would appreciate any ones helpful info. thanks
_____________________________
"If u cant find something to live for, u best find something to die for."-Tupac
Post #: 1
RE: V8 convertion Questions - 1/31/2008 8:51:46 AM
cplthomas
Score: -2
Status: offline
cplthomas's photo gallery
It should be fine, most of what will need are already there.  You will need to replace the ecm and upgrade the mounts.  There is more to it obviously but these are two things that you will most likely find.  Fuel delivery system as well, the pressure for the 3.8 is different for an ls1 or ls2.  Just a couple of things.  I once put a 4.3 v6 in an S-10 that had a streight 6 in it, those were the biggest issues I had, and the cooling system needed changing.  The more parts for the ls1 or ls2 you start with is the less parts you will have to buy.
I say go for it, you can only learn from any mistake.
Urramaich a eorna
Land of the free because of the brave.
*warning* I dont care about spelling and spell things the way they sound.
these -> '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' <- are my fav
(in reply to dodge destroyer)
Post #: 2
RE: V8 convertion Questions - 1/31/2008 3:33:41 PM
bowtie4ever
Score: 0
Status: offline
That tranny will not hold up to a v-8 bro, I've seen this in the past, you are going to have to buy an LT-1 donor car pretty much, buick roadmaster,caprice, camaro whatever... I just bought a 2500 HD w/ 6 liter and I'm trying the same, basically everything that is hooked up to the motor has to go with it, and get the computer reprogrammed, it can be done though and I wish you luck....just wish me luck with mine in return, I have a 95 w/ 3.4 and it's time for the LQ9 I think, I also picked up a 93 z-28, LT-1, T-56, Posi, everything together running, w/ a new paint job for 1000.00, the guy thought the motor was locked up.......bad starter...lol., I did not let him know though.yep, i am lucky sometimes
(in reply to cplthomas)
Post #: 3
RE: V8 convertion Questions - 2/1/2008 11:23:58 AM
Camaro 69
Score: 0
Status: offline
The bellhousing of your 3.4 v-6 trans won't bolt up to the v-8, it's smaller. The 4.3 v-6 is a different animal, it's basically a sawed off small block v-8.
Post #: 4
RE: V8 convertion Questions - 2/1/2008 5:35:58 PM
importmd
Score: 0
Status: offline
importmd's photo gallery
Im in the middle of doing this swap right now.  Its more work then you think.  I have a 94 z28 that im using as a donor for my 95 v6 camaro.  this is the only way to do this swap.  the suspension is diffrent, rear end, all the wiring, cooling system, fuel pump.  you need to swap the entire front chasis wiring along with the dash wiring and gauge cluster, the dash wiring goes all the way back to the hatch, so you have to rip the entire interior apart. the only way to do a lt1 swaw is to have a donor car. good luck
(in reply to Camaro 69)
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 4th Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604225
madmikez284192
95slvrz283155
02stangt3010
74454bb2749
cplthomas2562
bluovlh8er2469
blade2300
spartan662266
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
