RE: car shuts off for no apparent reason
Login | |
RE: car shuts off for no apparent reason - 5/29/2006 1:54:17 AM
vicki
Ok, I have driven it about 200 miles with no problems, tell your mechanic to ck the CPS sensor, I really believe this has fixed mine this time, good luck
RE: car shuts off for no apparent reason - 5/29/2006 10:56:05 AM
ChaoticBastard
I figured that was it Vicki.Good luck to you and your car
RE: car shuts off for no apparent reason - 5/30/2006 4:40:39 PM
camarocrisis
Vicki, I hope you are still up and running. I was hoping that I would have some good news to report today,cause I was supposed to pick up my car. I called to confirm that it was ready, and if the mechanic had broke down at all over the weekend. He did not have one breakdown and seems to think that the grease he cleaned my cps with has done the trick. He was fixing my windshield wiper motor, my wipers go about 3/4 of the way down, when he broke my windshield. Sooooo I guess it will be another couple days before I can say that I too am up and running.
RE: car shuts off for no apparent reason - 6/4/2006 2:01:12 PM
vicki
Hey camaro crisis, the CPS sensor was my problem, I have driven it for over a week and put over 500 miles on it and it is FIXED, finally, so try that with yours, it fixed mine......good luck
RE: car shuts off for no apparent reason - 6/5/2006 2:25:36 AM
camarocrisis
Vicki, I am so glad to hear you are still doing great. I am also glad that you didn't listen to me and just get your cps cleaned. I broke down on the way home from my mechanics again. When I started it up it was doing that thing you described with the idling,my rpm's were going up and down, up and down,like it was breathing. I knew right then that it was not going to last long. Sure enough, I got about a mile down the road and broke down. When I got it started, I went right back to the mechanics and told him to order the cps. It is supposed to be in Monday. I want to have a happy ending like you have. I can't wait. Good luck to you.
RE: car shuts off for no apparent reason - 6/5/2006 5:33:35 PM
camarocrisis
Vicki, I had my new cps put on today and felt so confident that my car was finally fixed... Wrong.... I was doing fine until I turned my air on, and then just like always, it just died on me. I got it started after about six tries and called the mechanic. The only thing he can think of is to put my computer on the front passenger seat and tap it when I have a breakdown. I am not clear as to what this is supposed to accomplish. I can't tell you how dissappointed I am that the cps replacement didn't work. Does anyone else have any ideas for me?
RE: car shuts off for no apparent reason - 6/6/2006 12:50:11 AM
ChaoticBastard
Fuel pump possibly
RE: car shuts off for no apparent reason - 6/6/2006 3:11:33 AM
camarocrisis
Will get the fuel pump checked out tomorrow when the mechanic puts the computer on my front seat. Maybe I need more than one thing.
RE: car shuts off for no apparent reason - 6/7/2006 8:50:13 AM
vicki
Camaro crisis, I am so sorry to hear that did not fix your problem, I had already had my fuel pump tested, don't know if you knew that, so I knew it was not my fuel pump, my mechanic said just like chaotic bastard stated, it could be the cam shaft sensor if not the crank shaft sensor, as neither of those will throw a code on the computer, it might also be your maf sensor, there is a way to ck those to see if they are bad if your mechanic has the right meter, have him tested b4 you buy anything else and good luck to you. Mine appears to have been the crankshaft sensor, as I have been driving it for 2 weeks and have put 800 miles on it and it is still doing fine, thinking about taking it out town next week....again I hope you solve your mystery, I know how frustrating it is believe me I do....
RE: car shuts off for no apparent reason - 6/7/2006 10:59:49 AM
camarocrisis
Vicki, Just knowing that someone else has had this same situation and has found the answer to their problem gives me hope that I will figure this out sooner or later. I really am happy for you. Thank you for your recent suggestions. I will have my cam shaft sensor and my maf sensor tested today and my fuel pump. Thought my appt. with the mechanic was yesterday, but its today. I told him its kinda sad when you have your mechanic on speed dial. He really is a good guy and thankfully hasn't given up on my car. I'll keep you informed on my progress.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
