RE: car shuts off for no apparent reason
Login | |
RE: car shuts off for no apparent reason - 6/8/2006 11:07:06 AM
camarocrisis
Vicki, I had the fuel pump. cam shaft sensor and the maf sensor tested and they all check out ok. We were not able to do the thing with the computer on the front seat because my mechanic thought my computer was located one place and come to find out it was located under the hood, so unless I could figure out how to reach my hand thru the hood, while I was driving, there was no way to do "the tap test". He has run out of ideas. I suggested he let me drive around with the scanner on it like someone else suggested, and he thought that was a good idea, but unfortunately they use their scanner dozens of times a day and I really didn't want to be responsible for a $7,000 piece of equipment sitting on my front seat....so next week I am going to leave the car with him and he is going to hook it up and drive it home from work and back to work, and hopefully this time he will have a breakdown and we can find out what is going on. I told him to drive like a little old lady instead of a speed demon and see if it breaks down on him then. In talking we found out the only thing we do differently is that he puts the air on before he cranks the car and I wait to put it on, if I put it on at all, because it seems like if I put it on it causes a breakdown. He told me to put the air on before I cranked it and see if any thing happens. I did that on the way home and it ran just fine. Of course that was only a 2 mile trip, and could have been coincidental. Wish me luck on this. I need it. If anyone out there has any other suggestions, or has any more ideas as to why it would breakdown when I turn on the air, please please speak up. I would be forever grateful, if we could figure this out. Again Vicki, I am so glad you are not having any more problems.
RE: car shuts off for no apparent reason - 6/14/2006 1:21:45 AM
Tom97V6
Is anyone else haveing the same problem i am where after it shuts off they are geting almost no voltage out of the battery like 6 or 7volts
RE: car shuts off for no apparent reason - 6/14/2006 1:43:05 AM
camarocrisis
Tom, I don't think anyone has thought to check my voltage,so for me the answer is no. I have been driving my car this week by starting my car with the air on, and then leaving it on, and have had no breakdowns. I have no idea why this works, only that it does. I wasn't able to leave my car with the mechanic because I had too many things to do this week to be without a car. Do you have any idea why this would keep it from breaking down? Try this yourself and see if the same thing happens. Good luck. Please keep us updated on your progress.
RE: car shuts off for no apparent reason - 6/14/2006 1:48:25 PM
94camaroLI
there is a way to check your computer with the "tap test". Turn your car on and lift the hood. Let it warm up for about 5 minutes. Then Tap your fingers with some force...if your engine stalls or feels like it's about to stall then you know your computer has a problem.
RE: car shuts off for no apparent reason - 6/14/2006 8:23:17 PM
camarocrisis
Hey 94, I'm not trying to be ignorant, but where exactly am I supposed to be tapping?
RE: car shuts off for no apparent reason - 1/25/2007 12:56:05 PM
Beavis
So Vicki has this still solved your problem? I have been going through thesamestuff you did word for word. i have taken it to two machanics and they both could not figure out what has been causing it. but if it has fixed your problem i'm hoping it fixes mine.
RE: car shuts off for no apparent reason - 1/25/2007 2:31:16 PM
MadMikeZ28
I hope her problem was fixed because the last post was in June 06!
_____________________________
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: car shuts off for no apparent reason - 1/25/2007 4:32:53 PM
Beavis
they always could have found something else. i took it in they said fuel pump i replaced. still dies. noone can honestly tell me whats wrong andi can't even drive it other then to and from work.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
