Which intake for my 305?
| Camaro Forums Sponsor |
Visit Magnaflow Today For More Information! |
Login | |
Which intake for my 305? - 2/4/2008 8:38:57 PM
walsh4nd
Hello, Im doing a carb swap on my 79 camaro with a 305 and figured i may as well swap the intake at the same time. I need some advice on picking the right intake. Right now i have a stock iron four barrel intake on the car. my first choice was the edelbrock performer. Is it necessary to buy an adapter plate to bolt a square bore edelbrock carb to the standard performer? It seemed to be a spreadbore setup. Next I saw the performer EPS in the Jegs catalog. Would this provide a worthwhile performance upgrade for the extra $50? Then after looking some more I found professional products intakes which seem to be exactly like the edelbrock without the name. So after all that research im still confused on what intake I really want...all I know is I want to keep the powerband from idle to 5500 and to have as much low end torque as possible...any advice would be greatly appreciated...thanks
RE: Which intake for my 305? - 2/9/2008 8:21:17 AM
1969 SS
Joined: 4/23/2006 From: Massachusetts Status: offline
just stay with a simpler dual-plane intake. you're not really going to get much of a power advantage with just an intake on that engine so just stay on the cheaper end of things and you will be happy. the 305 can be bogged down very easily and doesn't really have the lowend torque to be able to handle a big intake
_____________________________
I just try to do, what I can do, when I can do it http://www.myspace.com/northeast_rod_run/
