Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
z28 problems...any suggestions?
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V8 Tech >> z28 problems...any suggestions? Page: [1]
Login
Message << Older Topic   Newer Topic >>
z28 problems...any suggestions? - 2/5/2008 10:35:58 PM
redz28
Score: 0
Status: offline
i have a 95 z28 with a few problems and need some help
-when the engines cold is has a lot of trouble starting and will sometimes blow a little smoke underneath the car by the intake and sometimes has a little trouble starting wen warm also but not near as bad
-when i shift from park into gear it jumps forward about an inch or 2...there is a bearing that does need to be replaced at the end of the transmission but still not really sure if thats the issue
-when driving theres a howling noise coming from the rear axle, i tried some differential conditioner and it quieted down a smidge but only for a little while and still makes the noise
if u have any suggestions ur help would be greatly appreciated
Post #: 1
RE: z28 problems...any suggestions? - 2/6/2008 8:14:43 PM
chadyslim55
Score: 0
Status: offline
not sure about tranny and rear end but the starting thing I have had similar probs with. Might want to check your coil and or dist. I switched to msd for both and the problem hasn't arose since.
(in reply to redz28)
Post #: 2
RE: z28 problems...any suggestions? - 2/11/2008 2:26:06 PM
redz28
Score: 0
Status: offline
ok ill take a look and mess around with it a few, thanks for the help, appcreciate it
(in reply to chadyslim55)
Post #: 3
RE: z28 problems...any suggestions? - 3/13/2008 12:22:06 AM
1999TAmaster
Score: 0
Status: offline
Sounds like you might have a bad tranny mount, which is very common. You can pick one up at O'reilys for I think 35 buck. Make sure you get a good poly urethane one.  If they say they dont have one at O'reilys-which is what they told me-they are lying and just dont want to look up what one is needed.  As far as your first promblem my guess would be the opti spark, but is a complete guess
Post #: 4
RE: z28 problems...any suggestions? - 3/22/2008 12:17:19 PM
libertyforall1776
Score: 0
Status: online
Try some fuel system/injector cleaner like Lucas through a few tanks, every changed your fuel filter? Spray some throttle body cleaner to get rid of any stickage, varnish and gunk there.
Get a fuel pressure test -- your fuel pump may need replacing... I have this issue on my '95 3.4L...
Try removing the Diff cover, drain it, and replace full synthetic back in, along with any additives your manual requires/recommends.
Might want to replace that bearing, if you know it is bad!
_____________________________
01 Camaro SS Convertible: SLP FlowPac & Dual-Dual exhaust, G-Stop SS Brake Lines
02 Camaro RS Coupe: SLP CAI & Dual Exhaust,Whisper Lid
95 Camaro Coupe 3.4L: SLP CAI, Flo-Pro muffler
(in reply to 1999TAmaster)
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forum >> Camaro Models >> 4th Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
