1968 firebird .. rear end seems off-center!
Login | |
1968 firebird .. rear end seems off-center! - 2/22/2008 1:13:44 AM
knafel
Hi guys, I was measuring the rear fenderwell clearances on my 1968 firebird to decide for a wheel spacer and noticed that the right wheel sticks out about an inch more towards the fender lip than the left wheel. Also noticed that the right wheel is sitting an inch more towards the rear of the vehicle and the left wheel more towards the front... Has anyone heard of a such misalignment situation? It could just be the rear fender sheet metal, but I don't think so, this used to be a straight car, no sign of accidents or anything. When the snow is gone, I will pull the car on a lift and take measurements from underneath. Until then, does anyone have an idea? Could this just be standard tolerances? I know this is not a camaro, but it's the same body, I thought you guys could help me out. * I have 255/50/ZR16 tires and 16" AR TT2 wheels, both with same width and backspacing, nothing wrong there. * Standard rear drum brakes * Hotchkis sport leaf springs (about 1.5"-2" drop) * Bilstein shocks * Hotchkis rear sway bar* No traction bars installed
RE: 1968 firebird .. rear end seems off-center! - 2/23/2008 1:31:34 PM
JRs72RS
You may be just seeing a difference in the quarter panels. If someone replaced them it is very posssible they are not exactly the same. Before jumping the gun on any repairs or mods take measurements from the centerline of the car or use the frame raiils as a reference point. Has the diferential been replaced? I have seen where people have put coil rear end in leaf car and welded the perch mounts off center.
