Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
auto OD swap? or Gear change?
  Printable Version
Camaro >> Camaro Models >> 1st Generation >> V8 Tech >> auto OD swap? or Gear change? Page: [1]
Login
Message << Older Topic   Newer Topic >>
auto OD swap? or Gear change? - 2/24/2008 7:07:58 PM
speedracer7291
Score: 0
Status: offline
Hi all I am trying to figure out if I swap my trans with a 700 r4 OD unit what else do I need? I heard the driveshaft needs to be cut or does any company sell these already done? Or am I better off taking the 456 gears out of my 12 bolt posi and get 3 73's ? What rpm does 373 run at 65mph?
_____________________________
Bryan
69 camaro 350 v8 th350 12 bolt 456 posi rear
Post #: 1
RE: auto OD swap? or Gear change? - 2/25/2008 9:39:34 AM
1969 SS
Score: 0
Status: offline
with a 255/60/15 in the rear, and 3:73s I as running about 3,000RPM at regular highway speeds. overdrive is definitely the way to go.
as far as the driveshaft goes, just go to you local drivetrain specialist shop and they can cut yours to fit. they will tell you how to measure for it, and it will be a lot cheaper than a new shaft. you are better off having yours cut because when it comes to old cars, they are all a little different, so there really isn't anything too standard about them
I just try to do, what I can do, when I can do it
http://www.myspace.com/northeast_rod_run/
(in reply to speedracer7291)
Post #: 2
RE: auto OD swap? or Gear change? - 2/25/2008 11:29:39 AM
Camaro 69
Score: 0
Status: online
quote:
ORIGINAL: speedracer7291
Need your overall rear tire diameter to figure exactly.
Overdrive gives you the best of both worlds.
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 1st Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
