Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Turbo or N.O.S !?!
  Printable Version
Camaro Forum >> Brand Review >> Nitrous, Super Chargers, & Turbos >> RE: Turbo or N.O.S !?! Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: Turbo or N.O.S !?! - 3/15/2008 11:00:43 AM
cn_bailey32807
Status: offline
Turbo, its always there, you dont have to refill it and the power is there when needed. It might cost more at first but in the long run it will save you time & money. You could easily run about 7-8psi without changing the internals of the engine. However at 15psi you DOUBLE the amount of Horsepower the engine make alone. At 15psi you would most likely have to change internals to make around 8.0:1-8.5:1 Compression Ratio. Personally I think the turbo would be more dependable and cheaper in the long run.
(in reply to z28pete)
Post #: 11
RE: Turbo or N.O.S !?! - 3/15/2008 5:11:26 PM
BigNic
Status: offline
BigNic's photo gallery
like spectar said as far as cheaper in the long run it would be the loooong loooong run....60 bucks a bottle and 6 grand or more for a turbo installed and you can generally get 20 sprays or more  from a bottle ...... so thats like 100 bottles  X 20 sprays = 2000 runs thats alot alot alot of nitious runs....the only real issue with nitrous is as pete said legallity
_____________________________
note: some objects may be larger than listed in member title.
(in reply to cn_bailey32807)
Post #: 12
RE: Turbo or N.O.S !?! - 3/24/2008 7:11:29 PM
carguy_z28
Status: offline
carguy_z28's photo gallery
personaly, im a fan of nos... have it on my GTP, and on going on my blown C5 corvette...  But one thing was stated that is false... when you instal nitrous on your STOCK motor, you WILL need to drop the timing by 4 degrees on the LT1 when your doing your runs... Now, being a computor controlled engine, thats hard to do... so what you can do is get ( I forget the name) its a switch that will drop it for you when you go to use the spray...  Or else get the computor programmed to be constantly running 4 degrees less... You will get better MPG, but lose about 15 HP... If you DONT do this, then after about 6 or so runs, depending on the HP jets your using, you will grenade your engine.  I can promise you that.  You cant just plug in and go with the NOS... Its not that easy.
a true hotrodder would''''''''nt be content untill he had created a car so violent, so totally sick that the act of dropping the hammer could result in instant death.
*1974 Z28 N.O.S fed * 1995 Z28 M6 * 2007 F350 6.0 TD
(in reply to BigNic)
Post #: 13
RE: Turbo or N.O.S !?! - 3/25/2008 2:00:46 PM
th3po1son
Status: offline
th3po1son's photo gallery
get a ProCharger.  $4995 and it gives you 55-60 percent more HP.  if you can afford that go for it
1996 A4 Z28 all stock
http://cardomain.com/ride/3126040
(in reply to carguy_z28)
Post #: 14
RE: Turbo or N.O.S !?! - 3/26/2008 10:19:53 AM
BigNic
Status: offline
and i want to clairfy from the above post from the guy with like two posts running 15 psi will not double your horse power the aproximate gain from 1 pound of boost weather that turbo or supercharger boost is 7% of your natrually asperated horse power ie....
LT1= 285 horse
1% 2.85 * 7  19.95 horse per pound of boost
19.95 * 15
299.95+ base of 285 = 584 tad moe than double but.... your going to have to do a complete rebuild to run that sort of boost
(in reply to th3po1son)
Post #: 15
RE: Turbo or N.O.S !?! - 3/26/2008 10:33:28 AM
SpecterGT260
Status: offline
SpecterGT260's photo gallery
quote:
ORIGINAL: BigNic
LT1= 285 horse
19.95 * 15
wait.... I are confuse....
Guess who's awake...
quote:
ORIGINAL: BigNic
if she offers to shift for you its on.....
http://www.camaroforums.com/m_109346/mpage_1/key_/tm.htm#
Post #: 16
RE: Turbo or N.O.S !?! - 3/26/2008 10:43:20 AM
BigNic
Status: offline
it didnt exacly double is my point i hate when people make genralations about boost and....20 horse power is nothing to sneese at.... beyond that ......hows it going spectar...
(in reply to SpecterGT260)
Post #: 17
RE: Turbo or N.O.S !?! - 3/26/2008 10:49:20 AM
SpecterGT260
Status: offline
um... its going good.   u asked me this out of the blue in another thread and i couldnt figure out why.   am I dying or something?
quote:
ORIGINAL: BigNic
Post #: 18
RE: Turbo or N.O.S !?! - 3/26/2008 10:54:20 AM
BigNic
Status: offline
you disapeared for a while.... i was concrend that my gramactical mistakes and slight oversights might go uncorrected..... just glad to see you back bud.....
Post #: 19
RE: Turbo or N.O.S !?! - 3/26/2008 1:46:23 PM
carguy_z28
Status: offline
quote:
ORIGINAL: cn_bailey32807
HAHAHAHA,  Hey big nic... we should put this guy in a footlocker and fill it with shaving cream!!! LOL... My STOCK BLOCK, STOCK INTERNAL GTP grand prix has more than 15lbs of boost with the blower and pulley kit I have on it... and it runs awsome... You DO NOT double the ammount of HP with 15 PSI... its more than just PSI that makes the power... If that were the case, then My vette ( also supercharged ) should have about 800 HP... hmmmmmm nope..... dont think thats the case....
Post #: 20
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5507
spectergt2603834
madmikez283764
95slvrz282914
74454bb2688
02stangt2554
cplthomas2487
bluovlh8er2418
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
