corrosion problem on 69 camaro
Login | |
corrosion problem on 69 camaro - 3/12/2008 8:42:16 AM
scottlee1
Score: 0 Joined: 1/18/2008 Status: offline
i have a unique problem. Since ive repainted my block and put new bolts in i've got a problem with corrosion. Not rust corrosion but white scale. It is forming on bolts that are not zinc coated or stainless. I though maybe a grounding issue, so i checked the block ground and cleaned it again and regrounded. still scale seems to form, almost as if it were on the coast line in the salt air, but i leave 80-90 miles from the nearest coast line. I really didnt want to soak my engine in wd-40 to stop corrosion, Does anybody have any ideas on what to do or what may be causing this problem? thanks scott
RE: corrosion problem on 69 camaro - 3/12/2008 1:51:26 PM
Camaro 69
Score: 0 Joined: 10/17/2007 Status: offline
Which bolts are you talking about, and are they bare or painted? It sounds like you're describing a dielectric issue. You can get a build up of corrosion when you attach two dissimilar metals together, where there is a presence of electrolysis (such as internal flowing water), and also where there is a conductive path (ground). For instance, in home plumbing, if you were to attach a copper pipe directly to a galvanized pipe fitting, you will get a white crusty corrosion build-up where the two join. And, the house's plumbing pipes are also used as ground for the incoming power supply. In that case, you need to use a dielectric union which insulates the two from each other. Why you're getting it, I don't know. Is it possibly on your water neck bolts? I would think that using fiber washers as an insulator will most likely alleviate the problem.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
