Car is cold natured and why no t-stat!
Login | |
RE: Car is cold natured and why no t-stat! - 4/4/2008 7:30:45 AM
cplthomas
Score: -2 Status: offline
Welcome to the forums and thanks for the pic, nice ride. With your set up its going to sound like it want to die, this is from the cam, without knowing the numbers I cant say for sure but when you add the cam and the larger carb I would say the experiance you are having is probably normal. As far as 'pumping' the pedal, this is an old car, and unless almost all the components in the mill are new this will happen - I would recommend having the choke (if there is one) a good once over. A good tune up will give you a better idea of what might be wrong. As far as plugs go .... do you know the compression, any head work, what kind of fuel? Plug choice should depend on a few factors, they are heat rated and for maximum potential/tune the right ones can be determined by these variables - other wise get the most expensive ones
_____________________________
Urramaich a eorna Land of the free because of the brave. *warning* I dont care about spelling and spell things the way they sound.
RE: Car is cold natured and why no t-stat! - 4/4/2008 7:43:43 AM
RUQWKNF27
Score: 0 Joined: 4/3/2008 Status: offline
Car details 350 .30over 4 bolt main 194 ported and polished heads Lunati 480 cam 10 1/2 to 1 comp. Edelbrock air gap manifold with 750 dual feed vacumn secondary carb Muncie M21 4 sp. I run 93 octane
RE: Car is cold natured and why no t-stat! - 4/4/2008 8:15:07 AM
cplthomas
Do you know the specs of the cam? Just based off that I would say the sound is normal for a cammed mill. The choke is there (among other reasons..) to be used in colder weather, it adjusts the volume in the carbs to compensate for the vapor of the fual air mixture in the cold. If you have to pump the pedal the choke might be faulty - or its just because its a carb on an older car. There could be other things going on too, once the solid tune up is done there will be more data to filter to get a better idea.
RE: Car is cold natured and why no t-stat! - 4/4/2008 3:11:29 PM
Camaro 69
Score: 0 Joined: 10/17/2007 Status: online
You absolutely want to have a thermostat in place. A stat doesn't have an effect on cold engine starting, but it will alter your engine's current bahavior since the t-stat will change the way your engine heats up, and stays cool. With the stat out and driving in cool weather, the engine will take forever, or may never get up to full running temperature. With the stat in place while driving in severe heat, the coolant remains in the radiator (when the stat is closed) so that the radiator can do it's job of cooling the coolant back down before the coolant in the engine gets up to temp and opens the stat again. Running in the hot summer heat without a stat can cause the engine to overheat since the coolant isn't in the radiator long enough to cool back down sufficiently. So, you can now see how important that small piece of metal can be. Put in a thermostat before farting around with anything else. It could be that your choke isn't opening up fully because it thinks you still have a bone-cold engine when you actually don't, and now you're running too rich. If your's is a fair-weather driver, a 180 degree stat will work well.
RE: Car is cold natured and why no t-stat! - 4/4/2008 6:17:06 PM
z28pete
Score: 0 Joined: 8/7/2005 Status: offline
quote:
ORIGINAL: Camaro 69 You absolutely want to have a thermostat in place. A stat doesn't have an effect on cold engine starting, but it will alter your engine's current bahavior since the t-stat will change the way your engine heats up, and stays cool. With the stat out and driving in cool weather, the engine will take forever, or may never get up to full running temperature. With the stat in place while driving in severe heat, the coolant remains in the radiator (when the stat is closed) so that the radiator can do it's job of cooling the coolant back down before the coolant in the engine gets up to temp and opens the stat again. Running in the hot summer heat without a stat can cause the engine to overheat since the coolant isn't in the radiator long enough to cool back down sufficiently. So, you can now see how important that small piece of metal can be. Put in a thermostat before farting around with anything else. It could be that your choke isn't opening up fully because it thinks you still have a bone-cold engine when you actually don't, and now you're running too rich. If your's is a fair-weather driver, a 180 degree stat will work well. Exactly! No matter how many times repeted, there are still people that insist in removing t'stats and then complain about driveability. As for "cold natured", engines have no nature, they are machines. LOL
Pete
RE: Car is cold natured and why no t-stat! - 4/5/2008 8:56:44 PM
Paul
Score: 0 Joined: 8/30/2007 Status: offline
You definitely should have a thermostat. In the 34 years I have been driving I had many carbureted cars. I always pumped the gas pedal 3 times when starting a cold engine. In fact if it has an automatic choke you must depress the gas pedal at least once to activate the choke.
Paul Visit our photo albums at: http://www.laflammefamily.ca and http://www.more.laflammefamily.ca
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
