Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Camaro Overheating?
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> V6 Tech >> Camaro Overheating? Page: [1]
Login
Message << Older Topic   Newer Topic >>
Camaro Overheating? - 4/22/2008 12:09:43 PM
matthew9440
Score: 0
Status: offline
I got a 91 V6 Camaro RS and just recently it started running hot.
When it gets to about 220 the fan comes on then it stops a few minutes later.  When you turn on the Bi Levels the fan isn’t kicking on.  IDK what’s wrong but I was thinking maybe a coolant leak cause I just added coolant the other day and it was decreased by half in 3 days.
I was just wondering.  Because my dad says the biggest problem I need to worry about is the possibility of a blown head gasket.  I am real worried my baby is really hurting.  Somebody help me out!
_____________________________
Post #: 1
RE: Camaro Overheating? - 4/22/2008 12:16:39 PM
camaro_burns_all
Score: 0
Status: offline
well hows the engine coolant fluid in your car? did you check to see the fluid level is normal? Also if you do have a blown head gasket, the only way to find out is to do a compression test and see what it tells you.
Btw if you think you have a coolant leak, then check around the radiator to see if you see any green fluid dripping around. If you do, then you do have a coolant leak.
This site will you tell about the possible locations for a coolant leak and all you need to know to fix the problem. Good Luck Bro
http://www.aa1car.com/library/coolant_leaks.htm
< Message edited by camaro_burns_all -- 4/22/2008 12:34:57 PM >
LIVE FOR SOMETHING OR DIE FOR NOTHING©
(in reply to matthew9440)
Post #: 2
RE: Camaro Overheating? - 4/22/2008 4:21:41 PM
MadMikeZ28
Score: 0
Status: offline
220 is not hot. They run hot to burn cleaner. Loss of coolant is bad.
If you suspect a head gasket is blown causingh your loss of coolant you can remove the radiator cap and start the car and look at the coolant. If there are air bubbles coming out then that would be cylinder gasses pushing through. Or buy a block tester. It is blue liquid and a tube that you put onto the radiator neck and draw air into it. If the liquid turns green then there are cylinder gasses present.
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to camaro_burns_all)
Post #: 3
RE: Camaro Overheating? - 5/16/2008 3:06:57 PM
94CamaroSFI
Score: 0
Status: offline
94CamaroSFI's photo gallery
I wouldn't say that my 91 rs has an overheating problem, but my 94 never gets up to 210. Should I worry about my 91 getting between 220 and roughly 240? It never gets into the red zone but, its just new to me :P
94 Camaro 3.4L Manual Transmission, CAI, Magnaflow Exhaust
91 3.1L RS manual, CAI, 3.42 Rear end gears, Catback
(in reply to MadMikeZ28)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 3rd Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5507
spectergt2603834
madmikez283764
95slvrz282914
74454bb2688
02stangt2554
cplthomas2487
bluovlh8er2418
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
