Wiring Diagram 95 v6?
Login | |
Wiring Diagram 95 v6? - 4/22/2008 6:30:47 PM
herestolife1000
hey, i just got the car, it camewith an after market stereo, and a kit tohold it in the stereo slot, and something is wrong with the wiring(im guessing), and when they installed it they just cut the wires and tied them together and taped them, but maybe its supposed to be like this i really idk, but the wires that say "POWER" and "CAR BATTERY" coming from the radio are both tied onto the same single wire coming from the car. and whenever the car is off, the radio turns off(backlighting, sounds etc) but there is still a clock on it(supposed to be on while car is off)and the radio drains the battery when the car and radio are off(but the clock is still on) so can you tell me if the "power" and "Car battery" are hooked up correctly? and if not, could you give me a diagram or tell me what colors are what coming from the car(front speaks, ground, power,battery etc), the ones from the stereo are already labeld, thanks, sorry for the long post
RE: Wiring Diagram 95 v6? - 4/22/2008 7:11:52 PM
DeZ
from installdr, dash color - cd player color A Left Front Spkr (-) Light Gray - White w/ Black Stripe B Left Front Spkr (+) Tan - White C Right Front Spkr (-) Light Green - Gray w/ Black Stripe D Right Front Spkr (+) Dark Green - Gray E Ground Wire Black - Black F Not Used G Headlight Dimmer Wire Gray - Orange (if available) H Power Antenna Turn On Pink - (if available) Blue I +12 Volt Ignition Wire Yellow - Red J +12 Volt Battery Wire Orange - Yellow K Right Rear Spkr (-) Light Blue - Purple w/ Black Stripe L Right Rear Spkr (+) Dark Blue - Purple M Left Rear Spkr (-) Yellow - Green w/ Black Stripe N Left Rear Spkr (+) Brown - Green onto your problem i had the same problem with my eclipse, the female apdt was missing so there was no way for me to tell if i had hooked up correctly or not. but the simple solution is run your ( red,yellow wire them together ) along with your ground wire to the battery terminals. 18 gauge wire needed. the only bitch about this is you have to manually turn off and on and most likely lose all of your key acc features until you have key on.
_____________________________
97 fish out of water - totallie rookin 00 over fried rice - died 94 mustard stain - reelie fast dood
RE: Wiring Diagram 95 v6? - 7/1/2008 5:05:54 AM
carnage9
i doubt its your stereo first diconnect deck and see if the battery still dies
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
