Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
noise above 2000RPM
  Printable Version
Camaro >> Camaro Models >> 1st Generation >> V8 Tech >> noise above 2000RPM Page: [1]
Login
Message << Older Topic   Newer Topic >>
noise above 2000RPM - 5/2/2008 7:33:59 AM
mrherren
Score: 0
Status: offline
I just bought a 69 SS 350 (I’m assuming a clone because it does not have the original engine).  After the engine warms up and is under load I get a knocking noise that comes in around 2000 RPMS.  If I let off the gas the noise goes away.  I have not been able to reproduce it at idle in the garage.  The car has a 350, 4 speed, functional cowl hood, dual exhaust w/ headers.  The car has been sitting a garage for several years, mostly undriven. The noise almost sounds like crank bearings, but it does not happen all of the time. Any ideas would be greatly appreciated.
Post #: 1
RE: noise above 2000RPM - 5/2/2008 9:11:43 AM
Camaro 69
Score: 0
Status: online
First of all, congratulations on being smart enough to buy a '69!
Does it sound more like a solid knock sound, or could it be an octane knock you hear? If you had a rod knock, I would expect you to be able to hear something when revving it in the garage. What octane gas did you put in the tank, or is it still the old bad gas that was in the tank from sitting a number of years? And where is your timing set? Since your knock happens under load, I'm thinking you could be dealing with a tank of bad gas, or your timing could be too far advanced. If you have good gas, you can try backing the timing off a little (rotating the distributor clockwise) and see if that helps.
(in reply to mrherren)
Post #: 2
RE: noise above 2000RPM - 5/2/2008 12:24:05 PM
mrherren
Score: 0
Status: offline
 thanks for the ideas,  I'll check the timing this weekend.  If you are thinking timing could it also be related to the vacuum advance? I just put 92 octane gas in because it was empty, so that shouldn't be it.
(in reply to Camaro 69)
Post #: 3
RE: noise above 2000RPM - 5/2/2008 1:36:26 PM
GRIFF
Score: 0
Status: offline
GRIFF's photo gallery
How is the oil pressure? It could be a rod knock or a wrist pin or a lifterbut you should still be abile to hear it at idle. Detonation is more like a ping or rattle noise. My first guess would be a header gasket, I have a suburban with a 454 that has a manifold leak in one cylinder you dont hear anything at idle but get on the road and you can hear it. I can notice it in the drive if I rev it and can actually feel the exhaust leak with my hand. I need to fix it but the camaro needs line locks installed and plugs changed before Sunday so the Burb will wait till next weekend..
Post #: 4
RE: noise above 2000RPM - 5/2/2008 1:42:20 PM
Camaro 69
Score: 0
Status: online
You didn't tell me if the noise is more like a rod knock klunk sound, or if it's an octane knock (which sounds more marbley). I'd know it if I heard it, but it's a little hard to tell from where I sit.
Do you have a timing light? Check your initial timing (with vacuum advance disconnected), and back it off a couple of degrees. Connect vacuum back up and take it for a test run. Backing off initial timing  backs off the overall (full advance) timing as well. For best performance, getting the timing as far advanced as possible, without pinging, is where you want to be. If your engine has a lot of miles, you could also have some carbon build up inside the combustion chamber which can cause octane knock. A fuel additive (or even water injection) used over time can help to clean it out.
Post #: 5
RE: noise above 2000RPM - 5/2/2008 5:31:02 PM
mrherren
Score: 0
Status: offline
The oil pressure is good.  I don't know what the guy put in for oil (what weight), but i checked it and it looked pretty new. I do have a timing light so i'll check that this weekend.  I would say the noise is like a very loud lifter ticking, but again it seems to happen once the engine is warmed up and only under load.  thanks again for the ideas and suggestions!
Post #: 6
RE: noise above 2000RPM - 5/2/2008 5:44:43 PM
mrherren
Score: 0
Status: offline
BTW - if it is a wrist pin what is danger of continuing to drive it?  The guy i bought it from told me there was a noise, but said he didn't know what it was.  He could not figure it out and he took it to a shop and they didn't know.  They told him to just drive it.
Post #: 7
RE: noise above 2000RPM - 5/2/2008 7:36:52 PM
GRIFF
Score: 0
Status: offline
If you can rule out the simple things like the timing or the header gasket(inspect and change the gasket they are cheap) a very loud internal tick is not a good thing. It could be a bad lifter or a wiped out cam lobe or a whole bunch of other stuff ? It makes me nervous if the garage couldnt find it and just drive it is not good advice. To start with I would pull the oil filter cut it open and inspect it for metal particals and I have also used one of those telescopic magnets to put into the oil pan drain hole to search for metal(it sounds stupid but it works). If there isnt anything significant then I would try and see if the rocker arms were in adjustment, one being way out may siginal a problem. If they look good go to the timing and check it (a loud lifter tick just doesnt sound like detonation to me). If it still is there I would tear down the engine and inspect it.
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 1st Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5511
spectergt2603848
madmikez283783
95slvrz282921
74454bb2688
02stangt2573
cplthomas2489
bluovlh8er2450
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
