engine setups,
Login | |
engine setups, - 5/10/2008 8:43:59 AM
rileyz28
Just want to know what kind of set up and and different stuff that you are running on your camaros mostly heads intakes carb and cam thanks
_____________________________
It will never be fast enough
RE: engine setups, - 5/10/2008 4:22:22 PM
Saint Ebony
100% OEM 1987 IROC-Z28 5.0L TPI V8. If it counts as a modification I've got K & N air filters in it, but other than that it follows the original specs exactly. Edit: http://img.photobucket.com/albums/v634/SaintEbony/car/003.jpg
< Message edited by Saint Ebony -- 5/10/2008 4:30:58 PM >
* 1987 Chevrolet Camaro IROC-Z, TPI 5.0L/Auto * 1991 Eagle Talon TSi AWD, Turbo 2.0L/Auto
RE: engine setups, - 5/10/2008 5:13:28 PM
350rs
Joined: 4/23/2006 From: St. Louis, Missouri Status: online
350 tBi ( yes tbi for now). But im workin on going with a 650 Edelbrock Thunder series and a performer intake ( i still have to have the EGR valve) as for a cam ive got one picked thats gona run a 500 lift... forgot the duration though. But on a program i got with the correct heads, it will have 400 horse. I gotta find a set of 2.02 intake and 1.60 exhaust heads, not hard to do. Possibly going with a small shot of nitrous as well for a little extra fun when i want it, but not for awhile. Ive got that backed by the t-5 at the moment, possibly a TKO-500 or 600. Maybe a t-56 down the road a bit. Im going to be running a stock HEI distributor setup for now, but once its all up and running well ill stick a MSD kit on it for a hotter spark and ill get better plugs as well.
March 2008 Ride of the Month 89 RS, 60 over 350 crate, 5 speed.
RE: engine setups, - 5/10/2008 6:36:35 PM
MadMikeZ28
I have Trans Warp Drive!
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
