Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
400 sbc what heads do you recommend?
  Printable Version
Camaro >> Brand Review >> Engine & Internal >> 400 sbc what heads do you recommend? Page: [1]
Login
Message << Older Topic   Newer Topic >>
400 sbc what heads do you recommend? - 5/11/2008 7:24:04 PM
stuccoman
Status: offline
    I have a 400 sbc with flat top pistons and running 350 heads with 1.5 valves. It goes quite good now and have been running on these heads for a few years now. I feel that these heads are holding back the engine and would like to swap them out to a good set of aluminum heads. Everything else is up to par. Large cam, 2800 stall converter,, 390 gears, 750 holley, headers. I had the heads rebuilt 10 years ago ported and polished, spent close to 800 buxs on them back then. It took me a few years to get it all together and running, bought the block for 1500 buxs balanced, 20 over flat top pistons. Right now it is high compression, I have to run on premium or it pings when hot. I would like a set of heads that will bring the compression down a bit to run on regular, but I would like to bring the performance up if possible.
What heads do you guys recommend
thanks
Stuccoman
Post #: 1
RE: 400 sbc what heads do you recommend? - 5/11/2008 8:08:36 PM
dacats67
Status: offline
dacats67's photo gallery
i've got a set of Brodix track 1 heads on my 406 small block
Thumbnail Image
Attachment (1)
_____________________________
DaCats 67 camaro
dacats 56 bel air convertible
a true chevy fan
(in reply to stuccoman)
Post #: 2
RE: 400 sbc what heads do you recommend? - 5/11/2008 8:52:01 PM
Camaro 69
Status: online
You may already know this, but whichever heads you use, be sure to either get ones specific to the 400 block, or have the steam holes drilled to match the block if you use conventional small block heads. Otherwise you can have overheating problems. Your head gaskets can be used as a template.
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Brand Review >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604223
madmikez284186
95slvrz283155
02stangt3007
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
