RE: will not shut off
Login | |
RE: will not shut off - 5/21/2008 7:34:10 PM
383 79
quote:
ORIGINAL: MadMikeZ28 383 Does your idle high so it will not die when you put it in gear? If so then you may want a stall converter. And another thing people should check is their timing. It can cause hot spots. Has any one ever had thier timing so far off it caused their exhaust manifolds to glow? Yes, it dies when I put it in gear, unless its at operating temp. My converter stalls at like 2500, is that what you mean? just a bigger stall? or what? You lost me
_____________________________
'79 Berlinetta 383 Stroker Small Block 450+ hp 400+Tq 10 bolt chev 8.5" with 4.56 gears
RE: will not shut off - 5/21/2008 8:06:40 PM
MadMikeZ28
quote:
ORIGINAL: 383 79 Yes, it dies when I put it in gear, unless its at operating temp. My converter stalls at like 2500, is that what you mean? just a bigger stall? or what? You lost me I do not know your engines specs but I see by your signature it is not stock. Say you have a real lopey cam then you would need a stall converter so it will idle in gear.
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: will not shut off - 5/21/2008 8:08:44 PM
383 79
Off the top of my head, idk the specs for my cam, but it is between mild and extreme. Do you mean I should try a higher stall converter?
RE: will not shut off - 5/21/2008 10:10:39 PM
MadMikeZ28
You would no better than any one else because you drive the car. Maybe you could do some research or email the cam manufacture or have a mechanic or performance engine builder test your car out and see what they recomend.
