Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
will not shut off
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V8 Tech >> will not shut off Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
will not shut off - 5/13/2008 7:39:57 AM
rileyz28
Status: offline
hey when I turn the ignition off my car still wants to keep running but it acts like it sputters and like just keeps going I dont know how to explain it
_____________________________
It will never be fast enough
Post #: 1
RE: will not shut off - 5/13/2008 8:58:52 AM
Camaro 69
Status: online
Sounds like you may be describing run-on (dieseling)?
1) Is your engine running hot?
2) Severe carbon deposits on the pistons and in the heads can cause hot spots that can make the fuel keep burning after ignition is switched off.
3) If you hot-wired your cooling fan, and if it's still switched on when you shut down, it can act as a generator as it's free-wheeling and give your ignition a power feedback to allow the engine to continue running for a couple seconds.
(in reply to rileyz28)
Post #: 2
RE: will not shut off - 5/13/2008 11:30:37 AM
irocktheIROC
Status: offline
quote:
ORIGINAL: Camaro 69
no no no....my diagnosis? ITS POSESSED!! THAT THUR KAMERO IS EVIL!!! just kiddin we all know camaros are eveil...
The only thing going down in this car is the window cuz yo pussy stank!!!!!
~$~3rdGenMafia~$~
(in reply to Camaro 69)
Post #: 3
RE: will not shut off - 5/13/2008 11:52:40 AM
Camaro 69
Status: online
quote:
ORIGINAL: irocktheIROC
quote:
ORIGINAL: Camaro 69
no no no no....the real problem is that Camaros are so great, they just won't die!!! Yeah, that's it!!!!
(in reply to irocktheIROC)
Post #: 4
RE: will not shut off - 5/14/2008 2:59:25 AM
irocktheIROC
Status: offline
all of the above....Camaros are amazing friends, yes, i treat mine as a friend...i even tuck it in..Hahaha
~$~3rdGenMafia~$~
Post #: 5
RE: will not shut off - 5/16/2008 4:05:02 PM
oneals camaro
Status: offline
Im just putting this out there but maybe the throttle cable is set to high? But i don't know anything so you shouldn't listein to me.
1991 rally sport running open headers flow tech shorties 5.0
Post #: 6
RE: will not shut off - 5/20/2008 5:00:14 PM
94z28chevy
Status: offline
i now my friends ford truck with a 429 cobra jet duz that to but it stops when he run 93 octane
To see pics of my 85 Z-28 go to
http://www.cardomain.com/ride/3090728
and my 96
http://www.cardomain.com/ride/3137832
Post #: 7
RE: will not shut off - 5/20/2008 5:08:14 PM
73camaroSS
Status: offline
73camaroSS's photo gallery
thats cause its a ford duh
U.S.A. 1, love it or leave it. Muscle4Life!
Ford hahahaha. They Circled The Problem
http://www.youtube.com/user/73camaroSS
(in reply to 94z28chevy)
Post #: 8
RE: will not shut off - 5/20/2008 9:38:51 PM
383 79
Status: online
383 79's photo gallery
Hey, mine does that. Although my engine is set up completely different then yours, I do have a temporary solution of sorts. I have to have my idle way up, because my engine is really cold-blooded. It wont stay idling in gear unless its really warm. Basically, at operating temp, my engine idles at 900-1000 in gear, but in park or neutral, it goes up to like 1500-2000. If I shut my car off at the higher rpm, then it diesels for a good 5 seconds. To get it to shut off clean, I have to put it from reverse, and then park, and turn off my ignition before my rpm increases.
I have heard of a mechanism that ford used on their cars in the past, that I think acts like a choke. so it starves it as you turn it off. But, I'm not sure. I've just begun to look into it, I really don't like monkey business with my car. I just want to fix it right lol. I'll tell you if I come across anything.
< Message edited by 383 79 -- 5/20/2008 9:47:35 PM >
'79 Berlinetta
383 Stroker Small Block
450+ hp
400+Tq
10 bolt chev 8.5" with 4.56 gears
(in reply to 73camaroSS)
Post #: 9
RE: will not shut off - 5/21/2008 12:07:35 AM
MadMikeZ28
Status: offline
383
Does your idle high so it will not die when you put it in gear? If so then you may want a stall converter.
And another thing people should check is their timing. It can cause hot spots. Has any one ever had thier timing so far off it caused their exhaust manifolds to glow?
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to 383 79)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604223
madmikez284186
95slvrz283155
02stangt3007
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
