Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Not level but why?!
  Printable Version
Camaro Forum >> Camaro Models >> 1st Generation >> V8 Tech >> Not level but why?! Page: [1]
Login
Message << Older Topic   Newer Topic >>
Not level but why?! - 5/17/2008 9:28:18 PM
CamaroX69
Score: 0
Status: offline
I purchased a 69 camaro with a stock 350 back in '06 and this problem has been gradually getting worse. The car is much lower in the rear on the left side compared to the right rear side. (Id say about 2 inches between tire and quarter on right and about .5 inch overlap on left side) A while back the right front was sitting so low it scrubbed on the fender so I ended up putting some spacers in the coil springs and that fixed the problem for the front. I was told by many people changing out the leaf springs would level out the back, but it didnt and now has gotten so bad the tire will occasionally hit the inside of the quarter panel... Its a noticeable slant looking at it from the back and id really like some suggestions on what could be causing the problem! Thanks!
Post #: 1
RE: Not level but why?! - 5/17/2008 10:51:16 PM
Gorn
Score: 0
Status: offline
Gorn's photo gallery
Normally in the rear I would say its from torque but since its both front and back I say it lived some of its life being parked on the side of a hill. Or maybe a couple of owners back weight in at 400 lbs. I would not bang my head over it to much. The car is going on 40. It was designed to last 7-8 years. Your going to go nuts trying to figure out why stuff happened. Save the "But why's" for the 4 year old car that needs struts and springs. A first gen with saging springs was common 25 years ago.
_____________________________
67 RS/SS, 350/4 speed, 12 bolt, Power top, Full gauges
Dingers Build Thread
(in reply to CamaroX69)
Post #: 2
RE: Not level but why?! - 5/17/2008 11:15:16 PM
Camaro 69
Score: 0
Status: online
quote:
ORIGINAL: CamaroX69
How long ago did you put new rear leafs on, and did it make any difference at the time? Also, when you did the springs, did you also replace the old worn out upper and lower shackle bushings with new ones?
Post #: 3
RE: Not level but why?! - 6/24/2008 4:37:45 PM
Spiffav8
Score: 0
Status: offline
Did you remove the front springs?  I''ve heard of this type of problem when a front coil spring isn''t clocked properly.  It also could be that one of the leaf springs is de-arching.
What springs did you use?
(in reply to Camaro 69)
Post #: 4
RE: Not level but why?! - 6/24/2008 8:32:29 PM
CamaroX69
Score: 0
Status: offline
Sorry I havent responded sooner. I took the advice of the front springs and leafs and checked it all out. the front springs needed replacing so I went ahead and took care of that anyways. The most help came from getting the leaf springs re-arched. She is sittin pretty now, thanks for the advice!
(in reply to Spiffav8)
Post #: 5
RE: Not level but why?! - 6/24/2008 8:36:15 PM
Spiffav8
Score: 0
Status: offline
Let''s see a picture!
Post #: 6
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5504
spectergt2603831
madmikez283744
95slvrz282906
74454bb2688
02stangt2513
cplthomas2473
bluovlh8er2417
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
