Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Stroker kits
  Printable Version
Camaro Forum >> Brand Review >> Engine & Internal >> Stroker kits Page: [1]
Login
Message << Older Topic   Newer Topic >>
Stroker kits - 7/17/2006 2:20:10 AM
V1cinity
Status: offline
Can someone inform me of what and how a stroker kit works? I hear ppl saying they have this but I dont have a clue as to what it does. Thanks
Post #: 1
RE: Stroker kits - 7/17/2006 8:27:59 PM
CamaroCrazy1969
Status: offline
a stroker kit is usualy a crank(longer stroke than stock), rods and pistons for a engine block you obeuosly allready have. some kits may be diiferent. example...
a 383cid small block chevy is a common and most popular stoker kit. what makes it a stroker motor is that they use another crank with a longer stroke. this one using a 400 small block crank(3.75 stroke), machining the mains down to fit inside a 350 block. then using the right connecting rod lenth and piston (compretion height) to make it fit and your all set.
Fords popular 393, using a 351W block, 400M crank (3.85 stroke) machined to fit inside the block, stock 351W rods and 302 pistons
Pontiac nerds use 400cid blocks with 3" mains, and machines their 455 cranks mains from 3.25 to 3.0 making it another 455cid but with smaller mains (?)... because v8 pontiacs are the same demention 326-455 there is no big or small block. making it a little more easier to switch cranks. mostly running a chevy rod(cost wise) and a custom piston they can get away with 500+ inches with an aftermarket crank.
you will probalby hear alot of people bragging about a 383 strokers and flash the word "stroker" in their own conversations 20 times. my opinion its just a small bore 400 small block (?).
but it a no brainer to build stroker when rebuilding a motor, even if its a chevy, parts are cheep and give it a few more years and cheerios might offer it with 100 proof of purchases GOOD LUCK
_____________________________
10.40 @135mph
(in reply to V1cinity)
Post #: 2
RE: Stroker kits - 7/17/2006 8:59:10 PM
V1cinity
Status: offline
Thanks very much for the info. But my next question is...Does anyone make a stroker kit for a 207 3.4L. If thats even possible...
(in reply to CamaroCrazy1969)
Post #: 3
RE: Stroker kits - 7/17/2006 10:00:46 PM
CamaroCrazy1969
Status: offline
I never heard of such animal. but i dont get out much eather. you could always offset grind the rod journal if there is enogh meat on the crank. i dont think you would have a problem finding a rod to use. just a thought
10.40 @135mph
Post #: 4
RE: Stroker kits - 9/11/2006 10:29:36 AM
94CamaroSFI
Status: offline
94CamaroSFI's photo gallery
From what I've heard the 207 3.4L is actually a 2.8/3.1L stroked with a performance cam...
Post #: 5
RE: Stroker kits - 9/11/2006 10:26:00 PM
American Muscle 100
Status: offline
i really dont think so and if there is it would probably be expensive so might as well go and upgrade to a v8 camaro
(in reply to 94CamaroSFI)
Post #: 6
RE: Stroker kits - 9/18/2006 4:55:55 PM
DFENS
Status: offline
Then you could stroke a motor shorter, allowing for more rev's and attempt better power that way... but who wants to be different...
(in reply to American Muscle 100)
Post #: 7
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Brand Review >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604223
madmikez284186
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
