Cowl Hood Scoop
Login | |
Cowl Hood Scoop - 5/25/2008 7:22:01 PM
CCarRocks
I'm looking for a steel cowl hood scoop for my 3rd Gen Camaro. Rather than buy a coplete hood with scoop I'd rather just weld one on. I know I'v e seen them somewhere but haven't been able to locate one again. Point me in the direction of a seller for just the scoop. Thanks all, C-Car
RE: Cowl Hood Scoop - 6/1/2008 7:15:09 PM
Roy
I too have a 3rd gen and not sure which way is best to go; a non functioning scoop just welded to the hood can be found in both the Summit & Jegs catalogs. I believe the complete hood from Harwood or Year One would be the best choice for functionality, clearence and rigidity. I don't know about you, but I could use more clearence and I thought about going the "scoop" only option but then I think I'd need to cut the framing of the hood above the engine to clear a taller intake and air cleaner. I might be wrong and there is no hood framing above the center of the engine. The stock hoods are faily flexable and I believe would not tolerate any reduction to their framing hence my thought to go with a complete scooped hood from Harwood. Good luck, hope that you find the scoop yuou are looking for. Roy
_____________________________
Roy F. Satikas
RE: Cowl Hood Scoop - 6/1/2008 7:26:54 PM
CCarRocks
Well now that's more to think about. I hadn't covered the flex problem. I could weld in more stiffeners if needed. I'll go check both stores for the scoop. I know I've seen the weld in or pop rivet in scoops that give the apperance of a Harwood full hood. But finding them again has been a pain. I have to have a hole in my hood to clear the breather. I'm installing a EFI unit Eldebrock model 3500 & I'm sure it will be too tall for the stock hood. Thanks for the reply. I'll post photo's of my car when I learn how :) CCar
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
