3.1 slapping 2nd gear
Login | |
RE: 3.1 slapping 2nd gear - 5/29/2008 12:24:32 PM
SpecterGT260
Score: 0 Joined: 6/5/2007 Status: offline
probably doesnt have the torque to slap 3rd but would if it could. alot of trannies will kinda over-rev and feel like they shift hard down low. even my elantra does it
_____________________________
Guess who's awake... quote:
ORIGINAL: BigNic if she offers to shift for you its on..... http://www.camaroforums.com/m_109346/mpage_1/key_/tm.htm#
RE: 3.1 slapping 2nd gear - 5/29/2008 1:21:11 PM
SpecterGT260
if your are stock suspension you would be surprised how easy it is to chirp even good tires. a sudden jolt of torque will lift your axle up, decreasing the weight on those tires significantly. your tranny may or may not be shifting too hard. it sounds alot like just an older car running the way its going to run. it may be due to wear on an old engine, but i wouldnt worry too much about it.
RE: 3.1 slapping 2nd gear - 5/29/2008 4:10:37 PM
MadMikeZ28
Score: 0 Joined: 7/15/2006 Status: online
Different gears have different fluid pressures. Maybe that is why it "slaps" into second. Also do you have anything done on your race car there that would affect the lock up converter? A locked converter is making it a direct drive with no slippage and will cause tires to chirp.
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
