91 RS 3.1 v6 fuel pump problem...please help...
Login | |
91 RS 3.1 v6 fuel pump problem...please help... - 6/3/2008 9:44:32 PM
91 RS V6
Score: 0 Joined: 6/3/2008 Status: offline
i just bought a 1991 Camaro RS off a guy for $550 its a 3.1 Liter V6 5 speed manual...only has 100,000 miles on it everythings fine except the fuel pump....the guy said that he replaced it twice in the last 3 years of course i didnt want to go through the process of dropping the tank so i cut out a small section of the trunk right above the gas tank only to find that there were 4 steel gas lines leaving the assembly that fits into the gas tank there is not way to detach these fuel lines anywhere close enough to pull out the fuel pump i saw on a 4th generation there was a peice of the fuel line that broke apart just for this action but my 3rd gen doesnt i was told to cut the line and replace the small section with a hose the psi rating going through those lines is in 40's i dont kno what to do would someone please help me thanks, Ryan
< Message edited by 91 RS V6 -- 6/3/2008 9:59:06 PM >
RE: 91 RS 3.1 v6 fuel pump problem...please help... - 6/3/2008 10:18:44 PM
MadMikeZ28
Score: 0 Joined: 7/15/2006 Status: online
Well if you are going to be lazy and not drop the tank and want to cut the line either flare the two ends and use a coupler or a compression fitting.
_____________________________
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
