RE: HELP! My rear tires rub on the fender, what do i do?
Login | |
RE: HELP! My rear tires rub on the fender, what do i do? - 6/5/2008 9:43:02 AM
mikemaccham
hey also I rubbed the tires on the drive home, and about the depth of a nickle rubbed off the tread on the sides, should I try to make them replace the tires since they installed them? Or is it not a big deal as?
RE: HELP! My rear tires rub on the fender, what do i do? - 6/6/2008 10:22:42 PM
mikemaccham
I ened up buying shackles, which I will put on later. For now I bent the inside of the fenders so it doesn''t cut my tires up and lifted the car up, filled the shocks (to get the most pressure) and it seems to be fine for now.
RE: HELP! My rear tires rub on the fender, what do i do? - 7/3/2008 5:34:38 PM
jamesjunk
You could also get different wheels with the correct back spacing. in my old 70 I used air shocks and they worked fine. I believe the problem with shackles is not messing with the springs but changing the pinion angle of the rear end and stressing the universal joints.
RE: HELP! My rear tires rub on the fender, what do i do? - 7/4/2008 12:59:48 PM
Andross
One thing with my car... When I wanted to put my bigger tires on my Camaro the wheels would rub when I would drive at all... didnt even have to go over a bump to rub... I put Air shocks on it and it lifted it enough and dont rub what so ever... even over bumps. I know you said you tried the air shocks but did you notice if it rubbed at all after or not?
_____________________________
Current Project: 1979 Camaro
RE: HELP! My rear tires rub on the fender, what do i do? - 7/5/2008 11:02:29 AM
mikemaccham
yeah, I lifted them up all the way with the air shocks which is good..until the shocks leak and lower back down...(must need new shocks)
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
