Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
HELP! My rear tires rub on the fender, what do i do?
  Printable Version
Camaro Forums >> Camaro Models >> 2nd Generation >> HELP! My rear tires rub on the fender, what do i do? Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 7:01:08 AM
mikemaccham
Status: offline
hey guys,
I just switched from 235/60/14's to 275/70/15's on my rear two tires, to go from the standard look to a beefy look. When I was driving the car home every time i hit a bump I could hear the tires rub in the rear. I got home and noticed I had about a inch of clearence. I put air in the shocks and now have about two inches, but I don't think that's enough. What should I do? What can I do? The tire shop installed the tires so I could get smaller ones by getting them replaced....but I want to lift the back so that it clears the tires. The tires are flush with the fender, so I  don't think I could role the fender...or could I? Would new shocks fix it? I wanted to get that look of a lifted rear anyway, so what are my options? Is it expensive or a do it at home job?
THANKS!
Post #: 1
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 11:11:02 AM
mikemaccham
Status: offline
someone had mentioned using shackles or blocks to lift the back of the car, is that hard to do? Any one done it?
< Message edited by mikemaccham -- 6/4/2008 11:19:41 AM >
(in reply to mikemaccham)
Post #: 2
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 4:53:13 PM
74454bb
Status: offline
74454bb's photo gallery
You could use them, they are easy just 4 bolts on the rear leafs... next time get 275/50/15''s..... or 255/60/15''s
I''m guessing that you ment 275/60''s on the back.
_____________________________
www.horsepowerforums.org
www.carsbySS.com
www.blueprintengines.com
Post #: 3
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 5:01:50 PM
got3ofem
Status: offline
You can contact these guys,  http://www.p-s-t.com/default.aspx or these guys,
http://www.performancesuspension.com/coil-and-leaf-springs.html Ive used both places and they are very reliable. You may be able to get some "special" leafs for the back, or you may want to try finding a spring specialist in your area..possibly add a couple of leafs to your present set. Shackle extenders are a bad idea (IMO) they change the geometry of the rear end by overstressing the rear of the spring and may not be safe during hard cornering. Air shocks work fine as a back up for stiffer springs, but shouldnt really be the main lifting component in the event a line blows or a leak occurs. Hope this helps..
Post #: 4
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 5:05:20 PM
74454bb
Status: offline
yes shackles are bad... and new leafs would be the best bet.
www.carsbySS.com
(in reply to got3ofem)
Post #: 5
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 8:37:47 PM
Camaro 69
Status: offline
I see no problem (nor have ever had any) at all with using longer shackles. Opinions will differ, so take it as you will. Longer shackles aren''t putting extra stress on the springs, all they are doing is lowering the mounting point of the rear of the spring, which in turn lowers the whole axle. You still have the same amount of weight resting on your springs. When you analyze it logically, under acceleration the twisting torque is put on the Front of the springs anyway. Any cornering issues that could arise would be from the longer shackles allowing more bushing sway. But get yourself some heavy duty shackles, or even gusseted ones, as well as install poly bushings, and don''t sweat it. On average, every inch of extended shackle will give you an extra half inch of fender clearance. If you want to mess with your springs instead, take your existing ones to a spring shop, tell them what you want to get, and have them re-arched. It will cost you a lot less than new ones.
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
(in reply to 74454bb)
Post #: 6
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 8:49:46 PM
JRs72RS
Status: online
If you are so inclined as to replace the leaf springs, give these guys a call: http://www.huskyspring.com/
We have them build all of our springs. Their prices are very reasonable and they will build to suit your application.
(in reply to Camaro 69)
Post #: 7
RE: HELP! My rear tires rub on the fender, what do i do? - 6/4/2008 9:41:55 PM
mikemaccham
Status: offline
awsome guys! how much are these different options gonna cost?
(in reply to JRs72RS)
Post #: 8
RE: HELP! My rear tires rub on the fender, what do i do? - 6/5/2008 12:08:42 AM
RcrX
Status: offline
RcrX's photo gallery
i had the same problem with my car. i have 15x8 tt2s w/ 3 3/4 bs and 255/60/15 yokohama tires. first i  started by hitting the crap out of my finders, but that was only to help them cuttin into my tires. then i changed the leafsprings which helped for about a week and was a waist of money. ended up gettin a set of airshocks at orielly''s, which make it alittle stiffer but would rather have that then scuffed tires and rubbing.
http://www.cardomain.com/ride/2592769
Post #: 9
RE: HELP! My rear tires rub on the fender, what do i do? - 6/5/2008 9:40:20 AM
mikemaccham
Status: offline
so new shocks helps, do you think it would it raise it enough for the look i am going for?
going for this:
http://s7.photobucket.com/albums/y293/mikemaccham/?action=view&current=sidewheels.jpg
This is my car:
http://s7.photobucket.com/albums/y293/mikemaccham/?action=view&current=772gs.jpg
(in reply to RcrX)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 2nd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5502
spectergt2603830
madmikez283738
95slvrz282903
74454bb2688
02stangt2504
cplthomas2473
bluovlh8er2416
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
