Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
No fuel pressure at Fuel rail, 95 LT1,137K miles
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> V8 Tech >> No fuel pressure at Fuel rail, 95 LT1,137K miles Page: [1]
Login
Message << Older Topic   Newer Topic >>
No fuel pressure at Fuel rail, 95 LT1,137K miles - 6/5/2008 3:03:17 PM
Ltfan
Score: 0
Status: offline
The car cranks but no start. Spark is good but fuel pressure at the rail is zero. I have some idea what to look for but don''t know how to proceed. For example
1. Fuse or relay blown: I could not find either the fuse or relay?
2. Fuel Pump bad: If I knew which wire or wires go to pump, I can check out the voltage if it is there or not and go from there. Or there could be another way.
3. Fuel filter bad: I changed this filter at 80K miles, it should not have been plugged up with only city driving. Even if it was I should have some pressure reading and not zero.
Your help will be very much appreciated to fix this problem.
Post #: 1
RE: No fuel pressure at Fuel rail, 95 LT1,137K miles - 6/5/2008 10:11:10 PM
noz
Score: 0
Status: offline
last time i had this problem a was my fuel pump, i just sprayed the throtle body with some brake claner and it started right alway. you might want to try that just to start eliminating components.
(in reply to Ltfan)
Post #: 2
RE: No fuel pressure at Fuel rail, 95 LT1,137K miles - 6/16/2008 2:59:28 PM
meteoralp45
Score: 0
Status: offline
meteoralp45's photo gallery
did u run out of gas by any chance?
_____________________________
1997 Pontiac Trans Am 6 speed ttops
exhaust clip:
http://www.youtube.com/watch?v=beIlrA2HOXw
quote:
ORIGINAL: Puck90a
brian rules.
(in reply to noz)
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5504
spectergt2603831
madmikez283744
95slvrz282906
74454bb2688
02stangt2513
cplthomas2473
bluovlh8er2417
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
