Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Wheel hop
  Printable Version
Camaro >> Brand Review >> Suspension >> RE: Wheel hop Page: <<   < prev  1 [2]
Login
Message << Older Topic   Newer Topic >>
RE: Wheel hop - 6/25/2008 10:37:30 PM
Camaro 69
Status: offline
To put what causes wheel hop in simpler terms, think about the old-school stock rear leaf spring suspensions, as what’s in my ‘69. The natural tendency during acceleration is for the pinion in the rearend to want to rise upward. This causes the axle housing to rotate and put an upward load (wrap-up) on the front half of the leaf springs (forward of the axle). As the tires break free from the pavement, the springs rebound and they momentarily snap the tires in the opposite direction of travel. That’s what causes the rhythmic screech-screech-screech type of wheel-hop burnout. So to clarify, wheel hop is not caused by vertical or horizontal movement, it’s caused by the suspension re-coiling and snapping the axle back. The remedy for this is the addition of traction bars, ladder bars, or links to minimize or stop spring wrap-up completely. Now, apply the same concept to the more modern Camaro suspension. The way these are designed to prevent the pinion from rising is by use of the torque arm, which connects the pinion area of the rearend to the rear section of the trans. So when you accelerate, the torque from the rearend is trying like hell to lift the torque arm at the trans mounting. Any weakness, slop, or wear in the front mount or bushings, and the axle will be allowed twist up and give the same results as I described above. That’s why using poly mounts on both the trans to crossmember mount, as well as on the torque arm mount will help to alleviate that problem. Or, if you want to go overkill, you can install a remote mount torque arm bracket that takes the mount and the load off the trans, and puts it to the frame of the car.
_____________________________
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
(in reply to robsryd)
Post #: 11
RE: Wheel hop - 6/26/2008 11:05:59 PM
383 79
Status: offline
383 79's photo gallery
uhhh, Slapper bars :) Yay for leaf springs. As far as I know, the rear end actually twists back and forth because the leaf springs and everything kind of bunch up. It seems to happen on the verge of spinning, and hooking. Thats just how I see it. Feel free to tear it apart and fix it for me.
'79 Berlinetta
383 Stroker Small Block
450+ hp
400+Tq
10 bolt chev 8.5" with 4.56 gears
(in reply to SpecterGT260)
Post #: 12
RE: Wheel hop - 6/27/2008 6:55:00 AM
Camaro 69
Status: offline
quote:
ORIGINAL: 383 79
As far as I know, the rear end actually twists back and forth because the leaf springs and everything kind of bunch up. It seems to happen on the verge of spinning, and hooking...
That''s what I was describing, but in more technical terms.
(in reply to 383 79)
Post #: 13
RE: Wheel hop - 6/27/2008 8:59:42 AM
SpecterGT260
Status: offline
SpecterGT260's photo gallery
i gotta ask u to clarify to see where we are getting off. there IS movement in hop. I guess in the discussions we acted like the thing is actually bouncing off the ground. Its the vibration of the suspension applying higher and lower force to the wheels. this is an up and down motion, even if there is no actual measurable movement of components. what would be measured is the "weight" on the tire.
Guess who's awake...
quote:
ORIGINAL: BigNic
if she offers to shift for you its on.....
http://www.camaroforums.com/m_109346/mpage_1/key_/tm.htm#
(in reply to Camaro 69)
Post #: 14
RE: Wheel hop - 6/27/2008 9:51:33 AM
Camaro 69
Status: offline
Any resulting up and down movement you may get is the symptom, not the cause.
Simply put, cut your finger and it bleeds.
The bleeding isn''t the problem, the cut is.
Post #: 15
RE: Wheel hop - 6/27/2008 10:14:16 AM
SpecterGT260
Status: offline
oh yeah, thats what I was saying. i actually meant to specify the up and down was the result of the problem, i just got one of those dreaded cf.com asp errors after i tried to post and said F it
if you look back i did say that the cause of the problem was the binding of the parts which forces the axle against the spring
< Message edited by SpecterGT260 -- 6/27/2008 10:25:56 AM >
quote:
ORIGINAL: BigNic
Post #: 16
RE: Wheel hop - 6/27/2008 10:18:27 AM
Camaro 69
Status: offline
Uh-huh, yeah, sure you did!!!
(reply to first half of your response before you edited it).
I didn''t go back to your previous answer, sheesh that''s a whole page back!!!
I just answered your most recent question.
< Message edited by Camaro 69 -- 6/27/2008 10:34:06 AM >
Post #: 17
RE: Wheel hop - 6/27/2008 10:52:33 AM
SpecterGT260
Status: offline
quote:
ORIGINAL: BigNic
Post #: 18
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Brand Review >> Suspension
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5449
spectergt2603735
madmikez283657
95slvrz282767
74454bb2688
cplthomas2439
bluovlh8er2400
blade2299
02stangt2193
ninetysixyen2071
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
K&N Engineering, Inc.
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
