Wheel hop
Login | |
Wheel hop - 6/7/2008 5:40:45 PM
robsryd
What causes wheel hop during a posi burn-out? My 1987 Z-28 has terrible hop during a wheel spin. The trailing arms and the adjustable panhard bar are Edelbrock, springs and shocks are new(but cheap) and the brakes are in new shape. Can anyone shed some light?
RE: Wheel hop - 6/25/2008 6:34:13 PM
ninetysixyenko
okay. wheel hop, wheel hop is when the wheel moves faster than the body of the car wants to. so the wheel darts forward, metal and suspension stop giving/bending, and the wheel sling shots back into place. and reapeats over and over again. that''s wheel hop. unlike what most believe, it is NOT vertical movement, it is horizontal movement. for RWD, i don''t know how to fix it, but on FWD, you use engine/tranny mounts, to stop engine from giving. but that still leaves some wheel hop, and horrible vibration. they recently came out with traction bars(B-woody grade 8 steel bars) for FWD cars, i have a couple pics i''ll upload of them. work WONDERS. i''m sure there''s something similar for RWD cars. only problem i have with my bars, is i have about 2 inches of clearnace, and if i hit something, it wont shear/break the bolts or the bar.. it''ll bend my frame. has happened to alot of people.
_____________________________
dropped on megans, Full suspension mods, Full intake, Tsudo Catback, JL & Alpine Audio. quote:
ORIGINAL: SpecterGT260 ur being used. call jerry
RE: Wheel hop - 6/25/2008 6:46:20 PM
ninetysixyenko
ill get more pics and a burnout video tommorrow or friday.
RE: Wheel hop - 6/25/2008 6:53:04 PM
ninetysixyenko
my bad, that top pic is my new sway bar endlinks.. also grade 8, and 3/4"s think... here''s the Trac Bars:
RE: Wheel hop - 6/25/2008 7:00:23 PM
SpecterGT260
yenko, sorry bro but, at least for rwd, hop is vertical movement. tire pushes against suspension components. force on the tire is mostly foreward, but partially upward due to the way the tire spins. suspension effectively squats and tire lifts up losing traction. spring forces it down, resulting in alot of traction, repeating the cycle. this is possible because the suspension components are made to swing up and down. horizontal movement of even an inch is enough to exceed the elastic thresh hold of the metal and permenently bend it. now, relocation brackets bring the axle further downward with relation to the LCA. since the LCA is on a pivot the axle must swing backward in order to travel upward, this is fine and dandy when the car is stationary, but iwth some torque applied the tires squish the axle against the lca eliminating backward swinging and thus eliminating hop. any minor flexion of the control arm can allow is to swing up and allow the hop. i feel like drawing a picture. brb
Guess who's awake... quote:
ORIGINAL: BigNic if she offers to shift for you its on..... http://www.camaroforums.com/m_109346/mpage_1/key_/tm.htm#
RE: Wheel hop - 6/25/2008 7:10:12 PM
ninetysixyenko
spec, everywhere i''ve read, hop is 90% horizontal movement for front and rear wheel drive, and i dunno bout RWD, but on my car, my A-Arms can move up and down just as much as they could before the bars, but now, i have no hop what so ever. because those bars prevent wheel from slinging forward and backward. even in rain, i have absolutely no wheel hop. now, RWD could have some vertical movemnt, but im still pretty sure it''s mostly horizontal. as to how to get rid of it, i don''t know. before the bars, i NEVER was able to spin without hopping... and it hopped BAD, to where steering wheel was shaking, and CD player skipped horribly.
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
