Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
wont rev over 5 grand
  Printable Version
Camaro Forums >> Camaro Models >> 2nd Generation >> wont rev over 5 grand Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
wont rev over 5 grand - 6/13/2008 2:26:34 PM
73camaroSS
Status: offline
73camaroSS's photo gallery
so i just put a tach in my car and i was coming back from fishing and i was hauling a$$ and i was going to rev the hell out of it so i put it i second and smashed the gas down and my car was hauling intell it got around 70mph and about 5grand it would not go above 5grand.
_____________________________
U.S.A. 1, love it or leave it. Muscle4Life!
Ford hahahaha. They Circled The Problem
http://www.youtube.com/user/73camaroSS
Post #: 1
RE: wont rev over 5 grand - 6/13/2008 2:31:51 PM
73camaroSS
Status: offline
oh and my car has a 350/350th with a quadrajet carb,does anybody know why my car wont rev over 5 grand oh and also at about 70 mph in drive just cruiseing the car starts to shake and surge. so if any body knows how to fix this any help would be very helpful.
Thanks Tony
(in reply to 73camaroSS)
Post #: 2
RE: wont rev over 5 grand - 6/13/2008 9:26:38 PM
rustbucket0873
Status: offline
what year do you have, and what ignition system are you running in it?
Post #: 3
RE: wont rev over 5 grand - 6/13/2008 9:39:36 PM
bowtieguy
Status: offline
bowtieguy's photo gallery
sounds like its running out of air.this is common with 2-barrell carbs and little heads.does it spit and sputter at 5000 or does it just quit pulling at 5000
http://s160.photobucket.com/albums/t173/bowtieguy78/?action=view¤t=bccebedd.pbw
(in reply to rustbucket0873)
Post #: 4
RE: wont rev over 5 grand - 6/14/2008 10:52:46 AM
73camaroSS
Status: offline
its a 73 camaro SS lol it has a 350 out of a later pickup becuase trucks came with 4 bolt mains it was built about 15 years ago with fuille heads 2.02,.30 over and what ever else you do,has a four barrel carb HEI ignition all new cap rotor plugs plug wires that did not fix its problem. quits pulling at 5 grand it also has a 14inch open air cleaner which in new also.
Thanks Tony.
(in reply to bowtieguy)
Post #: 5
RE: wont rev over 5 grand - 6/14/2008 11:17:19 AM
73camaroSS
Status: offline
oh and also the motor is a little worn out smokes when you start it in the mourning.also runs fine in town runs smooth revs and takes off when i smash the gas,but its just in the higher speeds theat it runs like crap 65+mph it starts to lack power and shakes. if you guys need any more info let me know.
Post #: 6
RE: wont rev over 5 grand - 6/14/2008 11:18:28 AM
73camaroSS
Status: offline
had to revise that last post 4 times before it worked freaking forum gets worse every day.
Post #: 7
RE: wont rev over 5 grand - 6/14/2008 1:24:20 PM
rustbucket0873
Status: offline
the only thing i can think of right now... is that if its not a stock ignition module, it may have rev limiter build in. when you accelerating when you hit 5 g does it feel like you hit a brick wall like a govener kick in?
Post #: 8
RE: wont rev over 5 grand - 6/14/2008 3:28:18 PM
73camaroSS
Status: offline
no it trys but it takes a lot longer than it should it didnt all ways have this problem so i dont think its the ignition module.it starts to really slow down at 4600rpms and when it gets to 5 grand it sounds like it is trying but for some reason it just cant.
Post #: 9
RE: wont rev over 5 grand - 6/14/2008 4:17:23 PM
Gorn
Status: offline
Gorn's photo gallery
1: Timing is incorrectly set (not enough advance) Or Timing chain has play.
2: Carb is running out of fuel (fuel pump or filter) or an issue with float
3: engine can not breath (Cat, converter or smashed tail pipe)
4: Valve floating
5: Your secondary ignition (cap rotor wires) can not fire the plugs at the higher pressure cause by the higher load on the car.
67 RS/SS, 350/4 speed, 12 bolt, Power top, Full gauges
Dingers Build Thread
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 2nd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5469
spectergt2603748
madmikez283668
95slvrz282795
74454bb2688
cplthomas2449
bluovlh8er2403
blade2299
02stangt2232
ninetysixyen2072
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
K&N Engineering, Inc.
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
